23854 Discussions
Intel Graphics Control Panel still won't open!
LVand2
I have uninstalled the program, updated my drivers, restarted my computer several times and I still don't know what to do... Help!!!
n_scott_pearson
What system (be specific and include complete model numbers)? What version of Windows and what update level? What graphics driver package do you currently have installed? What graphics driver package are you trying to install?
АСаве
И у меня тоже самое , ставлю драйвер графики Intel® для Windows® 10 Версия: DCH 25.20.100.6577 (Последняя версия) ( Intel® HD Graphics 500 ),
после перезагрузки и подключения к интернету - Панель управления графикой вообще нет .
НЕ УСТАНАВЛИВАЙТЕ ЭТОТ ТИП ДРАЙВЕРА !!!!! Панели управления графикой нет , windows 10 pro x64 ( 1809 )
n_scott_pearson
First of all, if you have an older, non-DCH version of the Intel HD Graphics driver package installed, you may have to uninstall it before you can install any DCH-based driver package. Here is the process to use:
  1. Download the DCH Intel HD Graphics driver package onto NUC. Placing on desktop is fine.
  2. Disconnect from Internet. Unplug Ethernet cable and/or disable wireless.
  3. From Apps and Features, uninstall the older, non-DCH version of the Intel HD Graphics driver package.
  4. Reboot (keep internet disconnected).
  5. Install the DCH Intel HD Graphics driver package.
  6. Reboot.
  7. Reconnect internet.
  8. Test.
Secondly, the DCH-based installer packages do not install the Intel Graphics Control Panel any longer. The panel is instead delivered as a separate application. You download and install it from the Microsoft App Store.
Hope this helps,
АСаве
У меня нет магазина приложений Майкрософт , удаляю чтобы систему не грузил во время простоя , предпочитаю старую проверенную версию , вместо DCH , все четко и понятно , не нужно лишний раз подключать интернет .
n_scott_pearson
That's your choice - for now. Microsoft is likely going to force people to DCH drivers with the 1903 or worst-case 1909 update and this will mean that ancillary applications (like the Control Panel) will have to be installed from the App Store.
АСаве
В 1903 будет возможность удалить все эти не нужные приложения , а старые версии драйверов так и будем ставить с полным запретом на их обновление . И по сути плевать мы на них хотели . Я поставил старый драйвер и запрет на его обновление , и все работает замечательно .
Я прочел ваш совет выше , спасибо за пояснение , но после установки нового драйвера , ноутбук стал дольше загружаться , панель управления появилась , но спустя неделю я не смог ее найти , поэтому пришлось принять меры и установить прежнюю версию , может я решусь установить новую версию в конце этого года как будет настроение .
АСаве
Сделал все по вашему совету , драйвер установился , панель управления появилась в меню "Пуск" , после запуска выходит сообщение об ошибки на английском языке . Пришлось опять удалить и установить прежнюю версию , увы , но то что вы пишите - ерунда получается .
