23621 Discussions
Intel Graphics Driver update made screen too big (intel uhd graphics 630)
Saad_amin
Today after opening windows, I encountered a problem where the screen became too big i also have no restore points and i couldnt roll back the drivers nor the old resolution ( 1440x 1024). Now it is stuck at 1024x764.
Any help will be gladly appreciated.
thanks.
RamyerM_Intel
Hello Saad_amin,
Thank you for posting in the communities. I can see you posted that the driver update made the change; may I please know what specific driver version caused the change? Usually, this issue occurs when the system is not using the recommended resolution, were you able to check the Display Settings of your system and check for other resolutions? You may also post here the SSU logs of your system so I can become more familiar with your configuration. You may download it at this link: https://www.intel.com/content/www/us/en/download/18377/intel-system-support-utility-for-windows.html. Additionally, if you are using an external monitor, please share the monitor model and cable port used. I will be waiting for your reply.
Ramyer M.
Saad_amin
As you said, I am able to do those but I can't share the ssu logs I can tell my system parts
I3 10100
8gb ddr4
128gb ssd
1tb hdd
And the update was intel 6th to 10th gen gpu driver update 2024 q1
RamyerM_Intel
Hello Saad_amin,
Would you prefer if we continue our conversation by email for the SSU logs? We do need it as we need to check for errors and identify if your system is in optimal configuration. Kindly please let me know if you would like to consider this option. Thank you
Ramyer M.
Saad_amin
Can you tell me how to boot in safe mode in win 11
Saad_amin
# SSU Scan Information
Scan Info:
Version:"3.0.0.2"
Date:"04/02/2024"
Time:"00:00:53.8394665"
# Scanned Hardware
Computer:
BaseBoard Manufacturer:"Gigabyte Technology Co., Ltd."
BIOS Mode:"UEFI"
BIOS Version/Date:"American Megatrends International, LLC. F1 , 05/24/2021 12:00 AM"
CD or DVD:"Not Available"
Embedded Controller Version:"255.255"
Platform Role:"Desktop"
Processor:"Intel(R) Core(TM) i3-10100 CPU @ 3.60GHz , GenuineIntel"
Secure Boot State:"Off"
SMBIOS Version:"3.3"
Sound Card:"High Definition Audio Device"
Sound Card:"Intel(R) Display Audio"
System Manufacturer:"Gigabyte Technology Co., Ltd."
System Model:"H410M S2 V3"
System SKU:"Default string"
System Type:"x64-based PC"
- "Display"
Intel ® Graphics Driver Version:"Not Available"
- "Microsoft Basic Display Adapter"
Adapter Compatibility:"(Standard display types)"
Adapter DAC Type:
Adapter RAM:"0.00 GB"
Bits Per Pixel:"32"
Caption:"Microsoft Basic Display Adapter"
CoInstallers:"display.inf,MSBDA,Not Available,Not Available"
Color Table Entries:"4294967296"
Dedicated Video Memory:"Not Available"
Driver:"BasicDisplay.sys"
Driver Date:"06/21/2006 05:30 AM" edit: How? this machine's drive is just 2 yrs old
Driver Path:"C:\WINDOWS\system32\DriverStore\FileRepository\basicdisplay.inf_amd64_02da009b3d736cc1\BasicDisplay.sys"
Driver Provider:"Microsoft"
Driver Version:"10.0.22621.1"
INF:"display.inf"
INF Section:"MSBDA"
Install Date:"Not Available"
Installed Drivers:"Not Available"
Last Error Code:"Not Available"
Last Error Code Description:"Not Available"
Last Reset:"Not Available"
Manufacturer:"(Standard display types)"
Microsoft DirectX* Version:"DirectX 12"
Monochrome:"No"
Number of Colors:"4294967296"
Number of Video Pages:"Not Available"
PNP Device ID:"PCI\VEN_8086&DEV_9BC8&SUBSYS_D0001458&REV_03\3&11583659&0&10"
Power Management Capabilities:"Not Available"
Power Management Supported:"Not Available"
Refresh Rate - Current:"64 Hz"
Refresh Rate - Maximum:"64 Hz"
Refresh Rate - Minimum:"64 Hz"
Resolution:"1024 X 768" was "1440 X 1024"
Scan Mode:"Noninterlaced"
Service Name:"BasicDisplay"
Status:"OK"
Video Architecture:"VGA"
Video Memory:"Unknown"
Video Processor:
- "Memory"
Physical Memory (Available):"2.89 GB"
Physical Memory (Installed):"8 GB"
Physical Memory (Total):"7.83 GB"
- "BANK 0"
Capacity:"8 GB"
Channel:"Controller0-ChannelA"
Configured Clock Speed:"2666 MHz"
Configured Voltage:"1200 millivolts"
Data Width:"64 bits"
Form Factor:"DIMM"
Interleave Position:"Noninterleaved"
Manufacturer:"OM Nanotech Pvt. Ltd"
Maximum Voltage:"Not Available"
Memory Type:"Unknown"
Minimum Voltage:"Not Available"
Part Number:"V01D4L88GB1G81G82666"
Serial Number:"00000000"
Status:"Not Available"
Type:"Synchronous"
- "Motherboard"
BIOS:"F1, ALASKA - 1072009"
Caption:"Motherboard"
Chipset:"Not Available"
Date:"05/24/2021 05:30 AM"
Model:"Not Available"
Part Number:"Not Available"
PNP Device ID:"Not Available"
Product:"H410M S2 V3"
Serial Number:"Default string"
Status:"OK"
Version:"x.x" Edit: 1.0
- "Networking"
Intel ® Network Connections Install Options:"Not Available"
Intel ® Network Connections Version:"Not Available"
Intel ® PROSet/Wireless Software Version:"Not Available"
- "Realtek Gaming GbE Family Controller"
Caption:"Realtek Gaming GbE Family Controller"
CoInstallers:"Not Available"
Default IP Gateway:"Not Available"
DHCP Enabled:"Yes"
DHCP Lease Expires:"Not Available"
DHCP Lease Obtained:"Not Available"
DHCP Server:"Not Available"
Driver:"rtcx21x64.sys"
Driver Date:"01/02/2021 12:00 AM"
Driver Path:"C:\WINDOWS\system32\DriverStore\FileRepository\rtcx21x64.inf_amd64_516e5c9b75c49dc2\rtcx21x64.sys"
Driver Version:"1.0.0.14"
Index:"0002"
INF:"rtcx21x64.inf"
INF Section:"RTL8118AS.ndi.NT"
Installed:"Yes"
IP Address:"Not Available"
IP Subnet:"Not Available"
Last Reset:"04/02/2024 05:27 PM"
MAC Address:
Manufacturer:"Realtek"
Net Connection ID:"Ethernet"
NetCfgInstanceId:"
PNP Device ID:
Port:"Not Available"
Power Management (Low Power):"Active: Yes, Enable: Yes"
Power Management (Wake On LAN):"Active: Yes, Enable: Yes"
Power Management (Wake on Magic Packet):"Active: Yes, EnableWakeOnMagicPacketOnly: No"
Power Management Supported:"No"
Product Type:"Realtek Gaming GbE Family Controller"
Service Name:"rtcx21"
Status:"Enabled"
Type:"Ethernet 802.3"
- "Service Bindings"
Bridge Driver:
Client for Microsoft Networks:
File and Printer Sharing for Microsoft Networks:
Internet Protocol Version 4 (TCP/IPv4):
Internet Protocol Version 6 (TCP/IPv6):
Link-Layer Topology Discovery Mapper I/O Driver:
Link-Layer Topology Discovery Responder:
Microsoft LLDP Protocol Driver:
QoS Packet Scheduler:
VMware Bridge Protocol:
- "Settings"
*FlowControl:Flow Control:"Rx & Tx Enabled (3)"
*InterruptModeration:Interrupt Moderation:"Enabled (1)"
*IPChecksumOffloadIPv4:IPv4 Checksum Offload:"Rx & Tx Enabled (3)"
*JumboPacket:Jumbo Frame:"Disabled (1514)"
*LsoV2IPv4:Large Send Offload v2 (IPv4):"Enabled (1)"
*LsoV2IPv6:Large Send Offload v2 (IPv6):"Enabled (1)"
*PMARPOffload:ARP Offload:"Enabled (1)"
*PMNSOffload:NS Offload:"Enabled (1)"
*PriorityVLANTag:Priority & VLAN:"Priority & VLAN Enabled (3)"
*ReceiveBuffers:Receive Buffers:"512 (512)"
*RscIPv4:Recv Segment Coalescing (IPv4):"Disabled (0)"
*RscIPv6:Recv Segment Coalescing (IPv6):"Disabled (0)"
*SpeedDuplex:Speed & Duplex:"Auto Negotiation (0)"
*TCPChecksumOffloadIPv4:TCP Checksum Offload (IPv4):"Rx & Tx Enabled (3)"
*TCPChecksumOffloadIPv6:TCP Checksum Offload (IPv6):"Rx & Tx Enabled (3)"
*TransmitBuffers:Transmit Buffers:"128 (128)"
*UDPChecksumOffloadIPv4:UDP Checksum Offload (IPv4):"Rx & Tx Enabled (3)"
*UDPChecksumOffloadIPv6:UDP Checksum Offload (IPv6):"Rx & Tx Enabled (3)"
*WakeOnMagicPacket:Wake on Magic Packet:"Enabled (1)"
*WakeOnPattern:Wake on pattern match:"Enabled (1)"
RegVlanid:VLAN ID:"0 (0)"
S5WakeOnLan:Shutdown Wake-On-Lan:"Enabled (1)"
WolShutdownLinkSpeed:WOL & Shutdown Link Speed:"10 Mbps First (0)"
- "Realtek RTL8188CU Wireless LAN 802.11n USB 2.0 Network Adapter"
Access Point:
Authentication:"WPA2-Personal"
Caption:"Realtek RTL8188CU Wireless LAN 802.11n USB 2.0 Network Adapter"
Channel:"6"
Cipher:"CCMP"
Connection Mode:"Profile"
Default IP Gateway:
DHCP Enabled:"Yes"
DHCP Lease Expires:"04/02/2024 06:29 PM"
DHCP Lease Obtained:"04/02/2024 05:29 PM"
DHCP Server:
Driver:"rtwlanu_oldIC.sys"
Driver Date:"04/03/2016 12:00 AM"
Driver Path:"C:\WINDOWS\system32\drivers\rtwlanu_oldIC.sys"
Driver Version:"1027.4.630.2015"
Index:"0003"
INF:"rtwlanu_oldIC.inf"
INF Section:"RTL8192cu.ndi.NT"
Installed:"Yes"
IP Address:
IP Subnet:
MAC Address:
Manufacturer:"Realtek Semiconductor Corp."
Net Connection ID:"Wi-Fi"
NetCfgInstanceId: Network Name:
Network Type:"Infrastructure"
PNP Device ID:
Power Management (Low Power):"Not Available"
Power Management (Wake On LAN):"Not Available"
Power Management (Wake on Magic Packet):"Not Available"
Product Type:"Realtek RTL8188CU Wireless LAN 802.11n USB 2.0 Network Adapter"
Profile:"OPPO A15s"
Radio Type:"802.11n"
Receive Rate:"300 Mbps"
Service Name:"RtlWlanu_OldIC"
Signal Strength:"68%"
State:"connected"
Status:"Enabled"
Transmit Rate:"58 Mbps"
Bridge Driver:
- "Settings"
BWSetting:Bandwidth:"20_40MHz (1)"
EnableAdaptivity:EnableAdaptivity:"Auto (2)"
HLDiffForAdaptivity:HLDiffForAdaptivity:"7 (7)"
L2HForAdaptivity:L2HForAdaptivity:"F5 (245)"
QoS:QoS Support:"Support QoS (1)"
WiFiConfg:WiFi Config:"Performance (0)"
WirelessMode:Wireless Mode:"IEEE 802.11b/g/n (8)"
- "VMware Virtual Ethernet Adapter for VMnet1"
Caption:"VMware Virtual Ethernet Adapter for VMnet1"
CoInstallers:"vnetinst.dll,VNL_AdapterCoinstaller"
DHCP Enabled:"No"
Driver:"vmnetadapter.sys"
Driver Date:"11/02/2023 12:00 AM"
Driver Path:"C:\WINDOWS\system32\DRIVERS\vmnetadapter.sys"
Driver Provider:"VMware, Inc."
Driver Version:"14.0.0.8"
Index:"0017"
INF:"oem37.inf"
INF Section:"VMnetAdapter1.Install"
Installed:"Yes"
IP Address:
IP Subnet:
MAC Address:
Manufacturer:"VMware, Inc."
Net Connection ID:"VMware Network Adapter VMnet1"
NetCfgInstanceId:
PNP Device ID:
Product Type:"VMware Virtual Ethernet Adapter for VMnet1"
Service Name:"VMnetAdapter"
Status:"Enabled"
- "Settings"
*JumboPacket:Jumbo Packet:"Disabled (1514) (1514)"
*PriorityVLANTag:Priority / VLAN tag:"Priority & VLAN Enabled (3)"
*WakeOnMagicPacket:Wake on magic packet:"Enabled (1)"
EnableWakeOnLan:Wake on LAN:"Enabled (1)"
- "VMware Virtual Ethernet Adapter for VMnet8"
Caption:"VMware Virtual Ethernet Adapter for VMnet8"
DHCP Enabled:"No"
Index:"0018"
INF:"oem37.inf"
INF Section:"VMnetAdapter8.Install"
Installed:"Yes"
IP Address:
IP Subnet:
MAC Address:
Net Connection ID:"VMware Network Adapter VMnet8"
NetCfgInstanceId:
PNP Device ID:
Product Type:"VMware Virtual Ethernet Adapter for VMnet8"
Status:"Enabled"
- "Settings"
- "Operating System"
.Net Framework Version:"2.0,3.0,3.5,4.0,4.8"
Boot Device:"\Device\HarddiskVolume5"
Internet Browser:"Brave, Mozilla Firefox, Google Chrome,124.0, Internet Explorer,11.1, Microsoft Edge,122.0"
Locale:"United States"
OS Manufacturer:"Microsoft Corporation"
OS Name:"Microsoft Windows 11 Pro"
Other OS Description:"Not Available"
Page File:"C:\pagefile.sys"
Page File Space:"7.65 GB"
Physical Memory (Available):"2.90 GB"
System Directory:"C:\WINDOWS\system32"
Version:"10.0.22621 Build 22621"
Virtual Memory (Available):"10.15 GB"
Virtual Memory (Total):"15.48 GB"
Windows Directory:"C:\WINDOWS"
- "Installed Updates"
KB2151757:"Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 [28-12-2023]"
KB2151757:"Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 [28-12-2023]"
KB2467173:"Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 [28-12-2023]"
KB2467173:"Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 [28-12-2023]"
KB2468871:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2468871:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2468871v2:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2468871v2:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2478063:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2478063:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2533523:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2533523:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2544514:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2544514:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600211:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600211:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2600217:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2600217:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB5029517:"Update [8/26/2023]"
KB5034467:"Update [2/18/2024]"
KB5035853:"Security Update [3/15/2024]"
KB5035967:"Security Update [3/14/2024]"
KB982573:"Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 [28-12-2023]"
KB982573:"Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 [28-12-2023]"
SP1:"Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 [Not Available]"
SP1:"Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 [Not Available]"
- "Processor"
- "Intel(R) Core(TM) i3-10100 CPU @ 3.60GHz"
Architecture:"x64"
ATPO:"Not Available"
Caption:"Intel64 Family 6 Model 165 Stepping 3"
- "Chipset Name":"Intel(R) Core(TM) i3-10100 CPU @ 3.60GHz"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Core+i3+10100+CPU+"
CPU Speed:"3.60 GHz"
Current Voltage:"9. volts"
Driver:"Not Available"
Driver Date:"04/21/2009 12:00 AM"
Driver Path:"C:\WINDOWS\system32\drivers\intelppm.sys"
Driver Version:"10.0.22621.3235"
Ext. Family:"Not Available"
FPO:"Not Available"
INF:"cpu.inf"
INF Section:"IntelPPM_Inst.NT"
Level 1 Cache:"4 x 256 KB"
Level 2 Cache:"4 x 1024 KB"
Level 3 Cache:"6 MB"
Load:"2%"
Manufacturer:"GenuineIntel"
Model:"165"
Name:"Intel(R) Core(TM) i3-10100 CPU @ 3.60GHz"
Number of Cores:"4"
Number of Cores Enabled:"4"
Number of Logical Processors:"8"
Part Number:"To Be Filled By O.E.M."
Processor ID:"BFEBFBFF000A0653"
Revision:"Not Available"
Serial Number:"To Be Filled By O.E.M."
Service Name:"intelppm"
Status:"OK"
Stepping:"3"
- "Storage"
- "128GB SSD"
Capablities:"Random Access, Supports Writing, SMART Notification"
Caption:"128GB SSD"
Cylinder - Total:"15566"
Description:"Disk drive"
Driver Date:"06/21/2006 12:00 AM"
Error Code:"Device is working properly"
Firmware Revision:"ZD0R3G3E"
Heads - Total:"255"
Index:"1"
INF:"disk.inf"
Interface Type:"IDE"
Manufacturer:"(Standard disk drives)"
Model:"128GB SSD"
Partitions:"3"
Physical Sector Size:"512"
PNP Device ID:"SCSI\DISK&VEN_128GB&PROD_SSD\4&5D48514&0&010000"
Policies:"Read Retention Priority=EqualPriority, Write Retention Priority=EqualPriority, Scalar Prefetch=Not Available, Block Prefetch=Not Available"
Sectors - Per Track:"63"
Sectors - Total:"250067790"
Serial Number:"AA00000000004784"
Size – Available:"265.75 MB"
SMART Attributes:"Self-Test: 2 minutes, OK, Short Self-Test: 1 minutes, OK"
Status:"OK"
Tracks - Per Cylinder:"255"
Tracks - Total:"3969330"
- "C:"
Availability:"Not Available"
Caption:"C:"
Compression Method:"Not Compressed"
Description:"Local Fixed Disk"
File System:"NTFS"
Name:"Not Available"
Serial Number:"4CC2B813"
Size – Available:"0.35 GB"
Volume Dirty:"No"
- "SMART"
0x01 Raw Read Error Rate:0:"6"
0x05 Reallocated Sector Count:0:"10"
0x09 Power-On Hours:800:"0"
0x0C Power Cycle Count:961:"20"
0xAB Program Fail Count:0:"0"
0xAC Erase Fail Count:0:"0"
0xAE Power-off Retract Count:743:"0"
0xAF Power Loss Protection Failure:0:"0"
0xB5 Program Fail Count Total:13095776:"0"
0xBB Uncorrectable Error Count:0:"0"
0xC2 Internal Device Temperature:40° C:"0"
0xC3 Hardware ECC Recovered:0:"0"
0xC4 Reallocation Count:0:"0"
0xC7 CRC Error Count:0:"0"
0xCE Flying Height:67:"0"
0xCF Spin High Current:204:"0"
0xE8 Available Reserved Space:98:"0"
0xE9 Media Wearout Indicator:130:"0"
0xF1 Total LBAs Written:5826:"0"
0xF2 Total LBAs Read:16374:"0"
0xF9 Total NAND Writes:7919:"0"
0xFA Read Error Retry Rate:6193:"0"
- "ST1000DM010-2EP102"
Caption:"ST1000DM010-2EP102"
Cylinder - Total:"121601"
Firmware Revision:"CC43"
Heads - Total:"255"
Index:"0"
INF:"disk.inf"
Model:"ST1000DM010-2EP102"
Partitions:"3"
Physical Sector Size:"4096"
PNP Device ID:"SCSI\DISK&VEN_&PROD_ST1000DM010-2EP1\4&5D48514&0&000000"
Sectors - Total:"1953520065"
Serial Number:"Z9AT74DJ"
Size – Available:"528.98 GB"
SMART Attributes:"Self-Test: 105 minutes, OK, Short Self-Test: 1 minutes, OK"
Status:"OK"
Tracks - Total:"31008255"
- "D:"
Caption:"D:"
File System:"NTFS"
Serial Number:"BCF27E09"
Size – Available:"37.54 GB"
Volume Dirty:"No"
- "E:"
Caption:"E:"
File System:"NTFS"
Serial Number:"4C218E44"
Size – Available:"228.45 GB"
Volume Dirty:"No"
- "F:"
Caption:"F:"
File System:"NTFS"
Serial Number:"1C1EBE5B"
Size – Available:"262.99 GB"
Volume Dirty:"No"
- "SMART"
0x01 Raw Read Error Rate:208650265:"6"
0x03 Spin Up Time:0:"0"
0x04 Start/Stop Count:1918:"20"
0x07 Seek Error Rate:97948498:"45"
0x09 Power-On Hours:1624:"0"
0x0A Spin Retry Count:0:"97"
0x0C Power Cycle Count:1771:"20"
0xB7 SATA Downshift Count:0:"0"
0xB8 End-to-End Error Detection Count:0:"99"
0xBB Uncorrectable Error Count:3680:"0"
0xBC Reported Command Timeouts:131081:"0"
0xBD High Fly Writes:0:"0"
0xBE Temperature - Current:38° C:"0"
0xBE Temperature - Highest:38° C:"0"
0xBE Temperature - Lowest:32° C:"40"
0xC1 Load/Unload Cycle Count:1923:"0"
0xC2 Internal Device Temperature:38° C:"0"
0xC3 Hardware ECC Recovered:208650265:"0"
0xC5 Current Pending Errors Count:40:"0"
0xC6 Uncorrectable Sector Count:40:"0"
0xF0 Head Flying Hours:1516:"0"
0xF1 Total LBAs Written:7693362691:"0"
0xF2 Total LBAs Read:13041784457:"0"
...#SSU#...
those SSU logs.
RamyerM_Intel
Hello Saad_amin,
Regarding your inquiry on booting into safe mode in windows 11, you may use this link from Microsoft. Based on the log as well, you are using the Microsoft Basic Display Adapter, did you recently clean install your driver? Please send us a screenshot of your display settings as well as the model of your monitor so we can check other possible options.  I will be waiting for your reply.
Ramyer M.
RamyerM_Intel
Hello Saad_amin,
How are you doing? Is everything alright now with your system? Please let me know if you need further assistance and we will be there to help you. I will be waiting for your reply.
Ramyer M.
RamyerM_Intel
Hello Saad_amin,
I hope everything is well in your system. As we have not heard a response from you in the past days, we will proceed in closing this case. Should you need further assistance, feel free to create a new post and we will be there to assist you.
Ramyer M.
