23832 Discussions
Intel Graphics HD (Intel Atom x7-Z8700 Processor) - code 45
ddvir1
Hey,
I have a Beelink BT7 computer (http://www.bee-link.com/Beelink-MiniPC-TV-BOX-37-1.html Beelink BT7 Mini Pc Powered by Atom x7-Z8700 Processor - Beelink Mini PC - Beelink - Mobile - Powered by Discuz! )
it's based on Intel Atom x7-Z8700 Processor (there is no external graphic card).
I connect he PC to my TV by HDMI cable, then i saw the desktop on my TV but the sound I couldn't hear,
so I google it and found that I need to change the windows (win 10) sound settings - So I locket in the sound properties (playback tab) and show the disable devices
and I cannot find the TV (image attached).
Then I checked the drivers of the graphic adapter and i found that there is problem
with the Intel HD graphic - code 45 (image attached)
I update the graphic adapter driver to the last version (using windows search) and the problem didn't solved.
So I down load Intel possessor test kit and run it on the device and the result was that everything is OK.
One more thing: I checked witch graphic adapter windows used - and I found that it use Microsoft basic adapter (image attached)....
How can I solved this problem ??
Dvir
Hello valdvir,
Could you please let us know the driver version you are running? Please go to Device Manger> Display adapters> Intel(R) HD Graphics right click on Properties and then go to Driver, you will be able to see the version installed.
What is the Windows® 10 build version that you have installed?
Amy.
ddvir1
Hey Amy,
Thanks fr your answer
the driver version is 20.19.15.4308
and the win 10 build is 10586.589
I attached screen shoots.
wait for your instructions.
Dvir valdfogel
Thank you for the information.
Let's try by running Windows Updates, then update the Intel® HD Graphics version to this version https://downloadcenter.intel.com/download/26228/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=88345 Download Intel® Graphics Driver for Windows® 10 and Windows 7*/8.1* [15.40] use this method for the installation http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html How to Manually Install an Intel® Graphics Driver in Windows® 10 &... .
Let me know how it goes.
Amy.
ddvir1
Hey Amy,
I update th windows to the lasr update (you can see the attached image)
and now in the devaice manager I dont see the display adpters (even if i pree showhidden devices)
and I can't update the driver.
So whats next ?
Thanks again
Dvir
Can you try using the .exe file?
Amy.
ddvir1
Hey,
I tried to used the .exe file ant i got the attached massege
Dvir
Did you install the 32-bit or the 64-bit version?
In Device Manager go to View and make sure that Show hidden devices is checked, then in Action click on Scan for hardware changes.
Amy.
ddvir1
Hey Amy,
I tried both of thoes things and the windows didn't find the new hardware, and the display adpters section is gone.
I tried to install the 64 but version (you can see above that the windows is 64 bit).
Dvir
Is there any chance you can access in safe mode and try installing the driver manually?
One more thing, since this is related to Windows® 10 updates I would recommend repairing Windows® 10 with these steps https://www.youtube.com/watch?v=z-HKlr_3o0Q.
The content on the above site is not controlled by Intel. This information is offered for your convenience and should not be viewed as an endorsement by Intel for the merchants or services offered there.
Amy.
Hello /thread/107092 valdvir,
I am following up your thread; were you able to follow the suggestion mentioned above?
Amy.
ddvir1
Hey Amy,
Sorry for the late answer - i was in vacation
Unfortunately all of the above didn't work (I tried the safe mode and the windows repair tool).
I had a problem with another driver and I solved it by using a old driver - maybe that can be the issue in the graphic card as well ?
What is our next step >
Dvir
Since you already tried installing our driver but the issue is still there, the next step would be getting in contact with http://www.bee-link.com/forum.php Beelink Official website,SHENZHEN AZW TECHNOLOGY CO.,LTD - Mobile - Powered by Discuz!, it's possible that they are aware of the situation and can provide more troubleshooting steps in order to address this matter.
Amy.
ddvir1
Hey Amy,
I will try to ask in the beelink form.
but I have few anther question for you:
- I look in all the graphic drivers in the Intel support web, in each driver I look if hey support the Intel Atom x7-z8700 possessor (I think that this is the driver I look for) and I didn't find any,
is there is one like this (this possessor is not in the product list) ?
- If I look for Intel® Atom™ x5 I found but if (http://ark.intel.com/products/85475/Intel-Atom-x7-Z8700-Processor-2M-Cache-up-to-2_40-GHz Intel® Atom™ x7-Z8700 Processor (2M Cache, up to 2.40 GHz) Specifications ) I look for Intel® Atom™ x7 I dont find
(https://downloadcenter.intel.com/search?keyword=Intel%C2%AE+Atom%E2%84%A2+x7 Search downloads) - maby this is way i can't install it ?
I really appreciate your help,
Thanks alot,
Dvir
Intel provides generic driver for general purposes, in your case the drivers for your device should be provided by the computer manufacturer; however, you might find some driver from our end for this platform.
This is your processor http://ark.intel.com/products/85475/Intel-Atom-x7-Z8700-Processor-2M-Cache-up-to-2_40-GHz Intel® Atom™ x7-Z8700 Processor (2M Cache, up to 2.40 GHz) Specifications, the graphics controller for your processor is Intel® HD Graphics. This product is formerly known as Cherry Trail, this they key word for the search in https://downloadcenter.intel.com/ Drivers & Software. This is the latest driver for your platform https://downloadcenter.intel.com/download/26228/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=88345 Download Intel® Graphics Driver for Windows® 10 and Windows 7*/8.1* [15.40], you can tell by looking at the release notes https://downloadmirror.intel.com/26228/eng/ReleaseNotes_4501.pdf https://downloadmirror.intel.com/26228/eng/ReleaseNotes_4501.pdf, there you will see Cherry Trail listed as supported. So, this the best method for you to look drivers in our download center, get the driver and check the release notes for "Cherry Trail".
Amy.
