23833 Discussions
Intel Graphics Media Accelerator needs windows 10 support - when..
AMærs
We have 2 times Acer Iconia W510 and 1 W810 all with Intel Graphics Media Accelerator adaptors
You need to support those for Windows 10 - that must be fair as these are machines born with Windows 8
Attached is System Informaton data..
Hans_B_Intel
Hello All
Please note that systems with the Atom Z2760 will not have support for Windows 10* graphics drivers.
Graphics driver supported operating systems:
http://www.intel.com/support/graphics/sb/CS-034343.htm http://www.intel.com/support/graphics/sb/CS-034343.htm
EMaka
Hello! I also have a W511 tablet.
I've asked Intel support on twitter, but they wrote that Intel Graphics Media Accelerator supports only Windows 7. Maybe we will find a solution on this forum..
Dear Intel Support (ricardog_intel, allan_intel, hansb_intel or someone who cah help),
Acer W510/511 has Intel® Atom™ processor Z2760 (CloverTrail) with Intel® Graphics Media Accelerator 3650 (full specs http://cdn.cnetcontent.com/43/a5/43a5738e-d730-4c7a-a1c8-cc38e00af357.pdf here). It has never supported Windows 7. Its processor was designed for Windows 8/8.1 and powerful enough to run Windows 10. It actually runs Windows 10, but with some graphic glitches, and users are unable to update through Get Windows 10 app because of Intel GMA driver.
Please, could you contact developers and confirm that Windows 10 driver for our tablet will be released? Thanks!
ККолу
Здравствуйте! Имеется нетбук toshiba NB510-C5R с графическим адаптером Intel(R) Graphics Media Accelerator 3600 Series, у меня такой вопрос когда появится драйвер для него? чтобы я смог обновиться до windows 10. P.S. на нетбуке стоит windows 7. Заранее благодарю!
EMaka
Invictus69, вот по поводу этого видеоадаптера в Intel точно сказали, что поддержка платформы Cedar trail прекратилась на Windows 7 и новую систему на него установить не получится. Уже когда под него не вышли драйвера для Windows 8, стоило задуматься. Сожалею.
Здесь же мы с Beameх'ом просим драйвер для Intel GMA 3650 на более новой платформе Clovertrail. Несмотря на то, что видеоадаптеру всего 3 года, нас не хотят обновлять c Windows 8.1 на Windows 10
ККолу
Большое спасибо за ответ, буду знать
ККолу
Hello! A NetBook toshiba NB510-C5R with a graphics card Intel (R) Graphics Media Accelerator Series 3600, I have a question when you see the driver for it? so I was able to upgrade to windows 10. P.s. on a NetBook windows 7 worth. Thank you in advance!
Hans_B_Intel
Hello All
AMærs
OK.. I guess like the little * might imply that we will have to use the Windows 8.1 drivers instead and see how that fares.
In my case I will use an approach similar to the one mentioned in Acer support forum:
http://community.acer.com/t5/Windows-10/Iconia-W510-not-compatible-with-Windows-10/td-p/371975/page/7 http://community.acer.com/t5/Windows-10/Iconia-W510-not-compatible-with-Windows-10/td-p/371975/page/7
