23670 Discussions
Intel Graphics Software app won't load after update to Graphics Driver 32.0.101.6557/32.0.101.6262
Hombre1968
I have just updated my A310 driver to version 32.0.101.6557/32.0.101.6262 and since doing so the bundled "Intel Graphics Software " utility fails to start either at PC startup as a tray icon or when I select it from the start menu, even when I attempt to run it as administrator, this means my fan curve remains at the default which is way too loud, please can anyone help? I did a clean install of this driver and have rebooted. I have also started in safemode and used DDU to remove the driver and then reinstalled it but the issue remains.
Many thanks,
John
DeancR_Intel
Hi Hombre1968,
Thank you for posting in the Community!
I have noticed that you have tried clean installation and DDU of the latest driver. Is there any error code or message that pops up upon launching Intel Graphics Software? If yes, kindly provide a photo of the error to allow me to further check on my end.
Dean R.
Tamiya
Hallo
Habe das gleiche problem , startet garnicht mehr obwohl man alles deinstalliert und neuinstalliert .
egal welcher Treiber ob der selbe oder de alten komplett neuinstalliert .
bei einer komplette neuinstallieren Installiert er es garnicht mehr .
Fehler meldung ist das er das .NET Desktop Runtie 8.0.10 nicht findet .
Ist aber installiert auf dem Rechner.
Verbaut Ist eine Asrock A770 16gb
und ein Intel i9 11er
Win11 24h2 mit allen Updates
Hab das gleiche problem auch auf einen anderen Rechner mit einer A580 genau das selbe .
mfg
DeancR_Intel
Hi Tamiya,
This is noted however, I suggest creating a new thread for this inquiry to avoid further confusions
Dean R.
A77016
I'm having the same issue. A770
DeancR_Intel
Hi A77016,
I understand that however, I kindly suggest creating a new thread for this inquiry to avoid any further confusion.
Dean R.
DeancR_Intel
Hi Hombre1968,
Dean R.
DeancR_Intel
Hi Hombre1968,
Since I haven't received a response from you, I will be closing this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Dean R.
