- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
Hi to all,
I have my pc: https://www.hp.com/es-es/shop/product.aspx?id=6U3U8EA&opt=ABE&sel=DTP#technical-details
I have 2 4K monitors conected (HDMI 1.4 and DisplayPort) but only the conected to the DP port is sending 4K, the monitor that is conected to the HDMI port is on 1080p.
I had tryed all what i know, on paper HDMI 1.4 can display 4K, so i dont know what can be the problem, maybe 2 4K monitors its too much?
Thanks in advance
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello @JoseAGilç
· Is the cable that you are currently using an HDMI 1.4 validated? otherwise won’t be able to handle all that bandwidth.
- Follow these steps to generate an Intel® Graphics Driver report for the Intel® Graphics Control Panel or the Intel® Graphics Command Center. Report for Intel® Graphics Drivers.
- Please download and scan your system using our tool, Intel® System Support Utility so we can help check your system info first. Once finished downloading, open the tool, click on scan 'Everything', click next, then save the system information to a .txt file. Please provide the .txt file.
To run HDMI 1.4 in 4K must be needed: 5.97Gbps and the maximum supported by HDMI 1.4 is 8.16 Gbps, this means that is possible to display only 4k (3840×2160, 2160p, UHD) at 24Hz, due to 60Hz needs 14.93Gbps.
Once you provide us with that information, we will be able to check if it is possible to display 4 k on both monitors.
Isaac Q.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
I do have the same issue with two 4k monitor. Is there a solution or answer for it?
UHD graphics 770
Two Dell 4k S2721QS monitors. One connected with displayport 2.1 (4k) and the other one with high speed hdmi cable.
The resolution on the monitor connected with hdmi cable is not going more than 1920x 1080.
Please advise
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello @JoseAGilç
Thank you for your reply.
· Please provide us with the monitors make and models. It will be necessary to have both monitors specifications. Also let us know which is using DP and HDMI.
IGCC Report: Follow these steps to generate an Intel® Graphics Driver report for the Intel® Graphics Control Panel or the Intel® Graphics Command Center. Report for Intel® Graphics Drivers. This is necessary to continue with the troubleshooting.
Isaac Q.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello @JoseAGilç
We hope you are doing fine.
Isaac Q.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
I did not had time. I Will do It Next week, and Will send you all the details of the monitors
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello @JoseAGilç
We will be waiting for the information.
Have a good weekend.
Isaac Q.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello @JoseAGilç
Isaac Q.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello @JoseAGilç
Thank you for your reply. Also let us know which cable/port are using DP and HDMI.
Please provide us with the following:
- Intel® Graphics Command Center report:
- Open the Intel Graphics Command Center
- Navigate to the Support tab
- Select System Diagnostic
- Click Generate Report
- Select Save and name the output file.
Isaac Q.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Report Date: Monday, 03 June 2024
Report Time [hh:mm:ss]: 10:07:53 AM
Operating System: Microsoft Windows 11 Pro 10.0.22631
IGCC Version: 1.100.5435.0
Language: en-AU
Physical Memory: 15.7 GB
Current Resolution: 3840x2160
Processor: 13th Gen Intel(R) Core(TM) i5-13500T
Processor Speed: 1600 MHz
GFX Driver Name: Intel® UHD Graphics 770
Shader Version: 6.6
OpenCL* Version: 3.0
* Microsoft DirectX* *
Runtime Version: 12
Hardware-Supported Version: 12
Vendor ID: 8086
Device ID: 4680
Device Revision: 0C
GFX Driver Version: 31.0.101.4502
Dedicated RAM: 128 MB
Shared RAM: 8 GB
Max Supported Displays: 4
GFX Vulcan: 1.3.250
GFX GOP: 17.0.1079
* Devices connected to the Graphics Accelerator *
Active Displays: 2
* Digital Display 1 *
Display Name: DELL S2721QS
Display Type: Digital
Serial Number: D9RGZY3
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: DisplayPort
Maximum Image Size
Horizontal - 23.62 inches
Vertical - 13.39 inches
Supported Modes
640 x 480 (60p Hz)
640 x 480 (75p Hz)
720 x 400 (70p Hz)
720 x 480 (60p Hz)
720 x 480 (60i Hz)
720 x 576 (50p Hz)
720 x 576 (50i Hz)
800 x 600 (60p Hz)
800 x 600 (75p Hz)
1024 x 768 (60p Hz)
1024 x 768 (75p Hz)
1152 x 864 (75p Hz)
1280 x 720 (60p Hz)
1280 x 1024 (60p Hz)
1280 x 1024 (75p Hz)
1600 x 900 (60p Hz)
1600 x 1200 (60p Hz)
1920 x 1080 (24p Hz)
1920 x 1080 (25p Hz)
1920 x 1080 (50i Hz)
1920 x 1080 (50p Hz)
1920 x 1080 (60p Hz)
1920 x 1080 (60i Hz)
2048 x 1280 (60p Hz)
2560 x 1440 (60p Hz)
3840 x 2160 (24p Hz, 4K)
3840 x 2160 (25p Hz, 4K)
3840 x 2160 (30p Hz, 4K)
3840 x 2160 (60p Hz, 4K)
Power Management Support
Active Off Mode Supported
Raw EDID:
00 FF FF FF FF FF FF 00 10 AC 98 A1 4C 54 45 30
0A 22 01 04 B5 3C 22 78 3B 50 95 A8 54 4E A5 26
0F 50 54 A5 4B 00 71 4F 81 80 A9 C0 A9 40 D1 C0
E1 00 01 01 01 01 4D D0 00 A0 F0 70 3E 80 30 20
35 00 55 50 21 00 00 1A 00 00 00 FF 00 44 39 52
47 5A 59 33 0A 20 20 20 20 20 00 00 00 FC 00 44
45 4C 4C 20 53 32 37 32 31 51 53 0A 00 00 00 FD
00 28 3C 89 89 3C 01 0A 20 20 20 20 20 20 01 75
02 03 2A F1 54 61 01 02 03 04 05 06 07 10 11 12
14 15 16 1F 20 21 5D 5E 5F 23 09 07 07 83 01 00
00 68 1A 00 00 01 01 28 3C 00 56 5E 00 A0 A0 A0
29 50 30 20 35 00 55 50 21 00 00 1A 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0B
* Digital Display 2 *
Serial Number: 99RGZY3
Gamma: 2.2
Connector Type: HDMI
Maximum Image Size
Supported Modes
640 x 480 (60p Hz)
640 x 480 (75p Hz)
720 x 400 (70p Hz)
720 x 480 (60p Hz)
720 x 480 (60i Hz)
720 x 576 (50p Hz)
720 x 576 (50i Hz)
800 x 600 (60p Hz)
800 x 600 (75p Hz)
1024 x 768 (60p Hz)
1024 x 768 (75p Hz)
1152 x 864 (75p Hz)
1280 x 720 (60p Hz)
1600 x 900 (60p Hz)
Standby Mode Supported
Suspend Mode Supported
Raw EDID:
00 FF FF FF FF FF FF 00 10 AC 97 A1 4C 38 46 30
0A 22 01 03 80 3C 22 78 EA 50 95 A8 54 4E A5 26
E1 00 01 01 01 01 08 E8 00 30 F2 70 5A 80 B0 58
8A 00 55 50 21 00 00 1E 00 00 00 FF 00 39 39 52
00 28 3C 82 89 3C 00 0A 20 20 20 20 20 20 01 99
02 03 45 F1 54 61 01 02 03 04 05 06 07 10 11 12
00 6D 03 0C 00 20 00 38 44 20 00 60 03 02 01 67
D8 5D C4 01 78 80 01 E4 0F 01 00 00 68 1A 00 00
01 01 28 3C E6 56 5E 00 A0 A0 A0 29 50 30 20 35
00 55 50 21 00 00 1A 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E
* Other names and brands are the property of their respective owners.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello JoseAGilç
Best regards.
Isaac Q.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello JoseAGilç
Best regards.
Isaac Q.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
While they may seem to have the same issue, every user's issue is different. You have different hardware, different O/S or distro, different driver mix, different driver installation order, etc. and etc. In addition, Intel Customer Support wants to track each user's issue to completion separate from that of any other. They can't do that if you are a rider on someone else's issue (or worse, attempting to hijack the conversation completely). Please open your own conversation for your issue, using the Post a Question button in the root page for the forum. Include a full description of your issue, the model of your PC/laptop, etc. in your post. You can include a link back to this conversation if you wish - but please don't say 'I have the same issue' because invariably you don't.
If you want to save time, please download and run the Intel System Support Utility for Windows (or Intel System Support Utility for Linux). It will provide more information regarding the architecture of your system and what drivers you have installed. When you start the tool, select Everything, and then click on Scan. Once it completes the scan process, click on Next and then Save. Pick a name for the text file to create and click on Save to create it. You can then close the app. Finally, in the description for your issue, use the Drag and drop here or browse files to attach dialog (below the edit box for the body of your question), upload and attach this text file to the post.
…S
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
