Hello, I've a laptop with Intel UHD 620 graphics. I have a USB-C hub with power charging, 2 HDMIs slots I am using for 2 external monitors.
Somehow, I am able to use only 1 external monitor. The System > Display menu in Windows shows me alsothe 3rd one, but it isn't working.
I checked couple of threads here but have not found any solution so I'm attaching the outcome from the system scan already.
Any idea,why this is happening ?
According to the technical data, the ThinkPad E580 only supports 2 screens simultaneously:
You can try turning off the internal display to use both external monitors, but this will probably only work if you connect the monitors directly to the two video outputs, but not via the hub.
