23854 Discussions
Intel Graphics center not loading
JamesMay87
Stuck loading on this and cannot not get past this loading screen. Been at this for days and wont open.
megan3000
Valued Contributor I
Have you tried to uninstall the app and then re-download and install it again from the MS store?
JamesMay87
Yes I have tried and it didn't work
Jean_Intel
Hello JamesMay87,
  • When did the issue start?
  • Was there a major hardware or software change before the issue started?
  • Create a report using the Intel®️ System Support Utility (Intel®️ SSU)
You should confirm if the system meets the following minimum system requirements:
  • 6th Generation Intel® processor or newer
  • Windows® 10 version 1709 or higher
  • Windows® 10 DCH Intel® Graphics Driver version 25.20.100.6618 or newer
Jean O.
Jean_Intel
Hello JamesMay87,
I hope you are doing fine.
Jean O.
Jean_Intel
Hello JamesMay87,
I have not heard back from you. So we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
