22824 Discussions
Intel Graphics driver display yellow as green after reinstall
GeoRegHacker
I had to reinstall the graphics driver, and now yellow is green. Color settings in Windows 11 do not show any other choices
VonM_Intel
Hi GeoRegHacker,
Thank you for posting in our Community. If you’re seeing yellow appear as green after reinstalling the Intel Graphics driver, it might be due to something that happened during the installation process. Let’s work together to narrow this down. Just to confirm a few details so I can better assist you:
  • Could you please share a screenshot/photo capture or a short screen recording showing the exact issue? This will help me review it more accurately and identify a suitable solution.
  • Just to clarify, did you use Intel’s Driver & Support Assistant to install the driver, or was it done manually or via Windows Update? It would also help if you could share the steps you took when reinstalling the graphics driver.
  • Have you noticed if the color issue appears across all applications or only in specific ones (like browsers, games, or videos)?
  • If you've performed any other tests, please provide the details so we can avoid going over the same steps again.
Additionally, I'd like to delve deeper and verify specifics like the graphics models, precise driver versions, and any system errors. Utilizing the Intel SSU tool will enable me to collect detailed information about your system setup, which could aid in identifying the underlying cause of this issue
Have a nice day!
Von M.
GeoRegHacker
Hello Von, I used the Intel Driver app and in running the app it repaired the installed app. I have been using Intel Graphics Software app and found out the reducing hue it gets somewhat back to yellow but back to normal.
GeoRegHacker
AlHill
Reseat or replace the video cable.
[CoPilot is a virus]
GeoRegHacker
I forgot to say it's a laptop
AlHill
Then it could be a problem with the ribbon cable in the laptop that connects to the screen.
You could take it apart to determine, or take it to a repair shop.
VonM_Intel
Hello GeoRegHacker,
Thanks a lot for the update and for sharing what you’ve tried so far. I’m glad to hear that running the Intel® Driver & Support Assistant helped partially restore the display color; that’s definitely progress, even if it’s not quite back to normal yet.
I noticed that one of our Super Users, @AlHill, suggested reseating or swapping the video cable. That’s definitely a great next step, as a loose or worn-out cable can sometimes cause color distortion or tint issues. Have you had a chance to try that yet? If so, did it help, or is the issue still the same?
To help us dig a little deeper, could you please share a few more details?
  • A photo, screenshot, or short screen recording showing how the color looks would really help me see what’s happening.
  • Does the issue appear in all apps, or only in certain ones (like browsers, games, or videos)?
  • What type of display connection are you using (HDMI, DisplayPort, USB-C, etc.)?
  • Does the problem persist if you try a different cable or monitor?
  • What’s your current graphics driver version after the repair?
Additionally, I’d like to take a closer look at your setup by reviewing a System Support Utility (SSU) report. This will give me detailed system information and help identify any hidden factors contributing to the issue.
Von M.
VonM_Intel
Hello GeoRegHacker,
Von M.
