23832 Discussions
Intel Graphics is hanging Windows 10 startup.
RBill1
I have an HP Pavilion dv7 that was upgraded from Windows 7 to Windows 10 last August.
Before the upgrade there was no problem with the video. After the upgrade the system would apparently hang on startups and have to be repeatedly booted several times before it would stay up without hanging. The OS interface would start and I would start the Task Manager in Performance tab to monitor the CPU graph. If it stopped the cause was a display freeze. The reason is that certain features of the display would keep working such as the start button and the Action Center. After removing critical applications from the startup process I finally determined that the process was the system reported that the graphics driver had stopped and been reset. Then later the display which was frozen suddenly started working again after several minutes, indicating that there was indeed an issue with the graphics drivers and Windows 10 operating system. So far this issue has only shown itself while the system is loading. This problem can also manifest itself upon wake from sleep mode. If this does happen, there is no response and the only resolution is to reboot the laptop.u
Any help in resolving this issue would be welcome.
Thank you.
Here is the info from the display control panel:
Intel(R) HD Graphics 3000
Report Date: 11/2/2015
Report Time[hh:mm:ss]: 11:59:06
Driver Version: 9.17.10.4229
Operating System: Microsoft Windows 10 Home(10.0.10240)
Default Language: English (United States)
DirectX* Version: 11.0
Physical Memory: 6091 MB
Processor: Intel(R) Core(TM) i5-2410M CPU @ 2.30GHz
Processor Speed: 2295 MHz
Vendor ID: 8086
Device ID: 0116
Device Revision: 09
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 3000
Video BIOS: 2104.0
Current Graphics Mode: 1366 by 768
* Devices Connected to the Graphics Accelerator *
Active Notebook Displays: 1
* Built-in Display *
Monitor Name: Generic PnP Monitor
Display Type: Digital
Gamma Value: 2.2
DDC2 Protocol: Supported
Maximum Image Size:
Horizontal: 15.35 inches
Vertical: 08.66 inches
Monitor Supported Modes:
1600 by 900 (60 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Not Supported
Raw EDID:
00 FF FF FF FF FF FF 00 0D AF 19 17 00 00 00 00
05 13 01 03 80 27 16 78 0A 08 05 9D 58 53 97 29
15 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 1C 2A 40 54 61 84 1A 30 30 20
35 00 7E D7 10 00 00 18 00 00 00 FE 00 4E 31 37
33 4F 36 2D 4C 30 32 0A 20 20 00 00 00 FE 00 43
4D 4F 0A 20 20 20 20 20 20 20 20 20 00 00 00 FE
00 4E 31 37 33 4F 36 2D 4C 30 32 0A 20 20 00 AD
* Other names and brands are the property of their respective owners. *
Allan_J_Intel1
Please bear in mind your graphics controller (2nd generation) does not have graphics driver support for Windows 10. Intel supports Windows 10 starting with 3rd generation graphics
http://www.intel.com/support/graphics/sb/CS-034343.htm Graphics Drivers — Supported Operating Systems
Allan.
RBill1
I installed the latest Intel Driver Update Utility and ran it for Microsoft Windows 10 Home 64-bit machine, but it found nothing.
What do I do now?
How do I get the latest graphics controller?
Allan_J_Intel1
You could try running Microsoft Windows Updates to see if you will find generic graphics drivers for Windows 10 because at Intel, Windows 10 graphics drivers are not available for Intel® HD Graphics 3000.
Allan.
