23830 Discussions
Intel Graphics vs Intel Arc Graphics confusion with single vs dual-channel
YogeshSharma
Hello Intel Team,
I am planning to buy an ASUS laptop with Intel Core Ultra 5 225H or Intel Core Ultra 7 255H
The laptop comes with 16GB DDR5 single-channel RAM and one empty slot.
In specs and Windows, GPU is shown as “Intel Graphics”, not “Intel Arc Graphics”.
My question is:
  • Is Intel Arc iGPU physically present in all Core Ultra 5 225H or Ultra 7 255H processors?
  • Does adding another 16GB DDR5 RAM (dual-channel) automatically enables/detects Intel Arc Graphics?
  • If Windows still shows “Intel Graphics”, will the performance be equivalent to Intel Arc?
I want official confirmation before purchase.
Thank you.
YogeshSharma
Of course It will not give performance of dedicated graphics card. My concern is that it should use full potential of Integrated graphics card
AbraxasVi
Yes, the Intel Arc iGPU is physically present in the Intel Core Ultra 5 225H and Core Ultra 7 255H processors, but it requires a dual-channel RAM configuration to be fully activated and recognized as "Intel Arc Graphics".
Yes, the physical hardware for the integrated Intel Arc graphics (specifically the Arc 130T with 7 Xe cores for the 225H and Arc 140T with 8 Xe cores for the 255H) is built into the processor chip.
The "H" series Core Ultra processors are designed to use the higher-performance Arc architecture iGPU, unlike some "U" series or desktop counterparts with fewer cores which are branded simply as "Intel Graphics".
Yes, adding a second 16GB DDR5 RAM stick to enable a true dual-channel configuration is the key requirement for unlocking the full performance and official "Intel Arc Graphics" designation in Windows.
The system dynamically allocates shared memory (VRAM) from the system RAM, and a dual-channel configuration provides the necessary memory bandwidth for the Arc iGPU to operate at its full potential. The change in memory configuration should automatically trigger the proper detection and naming in the Device Manager and Intel Graphics Command Center after a potential driver update or system restart.
If Windows still shows "Intel Graphics", will the performance be equivalent to Intel Arc?
No, nomatter Windows continues to show "Intel Graphics" (or generic "Intel(R) Graphics") after adding the second RAM stick and updating drivers, you are not getting the full Intel Arc performance.
The "Intel Graphics" label generally indicates that the GPU is running in a reduced-performance, low-bandwidth mode due to the single-channel memory limitation. The performance difference between single-channel ("Intel Graphics") and dual-channel ("Intel Arc Graphics") mode is significant, as the latter allows the GPU to utilize the optimal memory throughput and all its execution units.
YogeshSharma
So if I add one more RAM of 16 GB DDR5, would it convert iGPU to Intel Arc Graphics automatically or I would have to do something else also ? Please elaborate
AbraxasVi
Even if you insert another 16GB DDR5 memory stick into that laptop, the drivers will automatically adjust the displayed device name to "Intel Arc Graphics". This detection is embedded within the firmware and drivers, requiring no manual operation on your part.
Remember, this action will not turn the integrated graphics card "into" a dedicated graphics card, nor will it make the graphics-related performance increase "dramatically". It will just be slightly better than before the memory was added.
YogeshSharma
Rayss131819
Hey, but what if you are a little budget constrained, and instead of 16GB extra RAM stick, you add 8 GB of RAM stick. Will that still unlock the ARC 130T IGPU. Because I am facing this situation right now. What difference will it make to add an 16 GB and 8 GB of ram stick? can any one tell me please.
RandyT_Intel
Hi @YogeshSharma,
The solution provided by the community member @AbraxasVi  is solid and aligns closely with the disposition outlined similar in this article. Why Does an Intel® Iris® Xe Graphics Eligible System Show It Is Using...
If you need any additional information, please submit a new question as this thread will no longer be monitored.
Best regard,
Randy T.
Rayss131819
Hey, but what if you are a little budget constrained, and instead of 16GB extra RAM stick, you add 8 GB of RAM stick. Will that still unlock the ARC 130T IGPU. Because I am facing this situation right now. What difference will it make to add an 16 GB and 8 GB of ram stick?  tell me please.
Sumit1
Hey @YogeshSharma
Are you able to unlock the arc 130t after adding 16gb ram? Looking to buy the same laptop and have same doubt.
I just want to make sure that the arc130t not disable at oem/bios level by asus.
Please let me know if adding extra 16gb ram worked for you.
Reihoron
Hi @Sumit1
I recently got an Asus Vivobook 16 X1607CA with Intel Core Ultra 5 225H and the Intel ARC Graphics 130T.
It originally comes with a soldiered 16GB DDR5-5600 single channel, and an empty SODIMM slot for an extra RAM stick.
At this point both the Task Manager and Intel Graphics Software says "Intel Graphics" only. It gets around 10fps in 3Dmark Speedway and around 20fps in Wuthering Waves lowest graphics preset with XeSS Performance.
Afterwards I bought another RAM stick with the exact specs, now both Task Manager and IGS shows Intel Arc 130T.
3Dmark Speedway now gets around 20fps and Wuthering Waves in lowest preset with Xess **Quality** gets around 40fps.
Although Intel recommends using the OEM driver, I had other issues (including bad performance and weird behaviour in games using vulkan) with the OEM driver from June 2025 (which MyAsus says it's the newest), so I also had to install the newest driver directly from Intel.
Here is a screenshot of my IGS after installing the extra RAM stick:
Hope this helps.
Leo_1223
Hi Reihoron
I wanna know if your device support OEM enablement, I got ASUS VIVOBOOK 14 X1407CA, and in the task manager, the graphic card show intel graphics not intel arc, so I wanna know if I added another 16GB RAM in the device will it be able to enable intel arc in the device, or there is something else I should know before I add Another RAM.
Reihoron
Hi Leo,
On my X1607CA, the system recognized the Arc 130T right after i added the second ram stick into the SODIMM slot, without BIOS settings or other extra configurations.
I would recommend getting your second ram with the same (or close) capacity (e.g. 16GB), speed (e.g. 5600MT/s), timing (e.g. 46-45-45-90) and voltage (e.g. 1.1v), because if they don't match, the faster module will slow down to match the slower module.
Although Intel officially suggest using the OEM driver, the one from Asus is quite outdated (an entire year old when i last checked) and has caused me multiple graphical and performance issues, therefore I personally suggest using the latest WHQL driver from intel directly instead.
n_scott_pearson
What it comes down to is you must have matching (size) DIMMs/SODIMMs in each channel in order to enable dual-channel mode. As well, you must be running in dual-channel mode in order to enable the iGPU's enhanced "Intel ARC Graphics" mode. If you use a 16GB DIMM with an 8GB DIMM, it will not run in dual-channel mode and you will only be able to use the iGPU in "Intel Graphics" mode.
Clear as mud?
