23821 Discussions
Intel HD 3000 HDMI overscan?
Hello! Ive been having some trouble connecting my PC to my sony bravia KDL-32U2530. There's not many options on the TV about HDMI settings so I guess the problem can only be fixed from the computer. MY TV's revolution is 1366x768 so that's where I have it even if the windows recommend 1920x1080. Well, I have tried many different things and possibilities with the resolutions and I can't make it work. any help would be much appreciated. thank you
Marcos_U_Intel
One of the reasons you are having problems with the resolutions of your monitor is because of the Extended Display Information Data (EDID) does not read properly when connected to some digital flat panel displays. Display devices describe their capabilities by sending EDID to the computer.
To solve your issue I recommend you follow the solution steps at the link below:
http://www.intel.com/support/graphics/sb/cs-028366.htm http://www.intel.com/support/graphics/sb/cs-028366.htm
Also try different HDMI cables and make sure you install the latest drivers from your monitor.
Michael
I installed the drivers but there's no difference at all. Not only that but it also changed the refresh rate at 29hz. However thanks for the reply.
Here's a diagnostic report in case you need it
Intel(R) HD Graphics
Report Date: 9/13/2012
Report Time[hr:mm:ss]: 3:4:23
Driver Version: 8.15.10.2279
Operating System: Windows 7 Service Pack 1(6.1.7601)
Default Language: English (United States)
DirectX* Version: 10.1
Physical Memory: 4013 MB
Minimum Graphics Memory: 64 MB
Maximum Graphics Memory: 1696 MB
Graphics Memory in Use: 92 MB
Processor: Intel64 Family 6 Model 42 Stepping 7
Processor Speed: 2607 MHz
Vendor ID: 8086
Device ID: 0102
Device Revision: 09
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics
Video BIOS: 2117.0
Current Graphics Mode: 1366 by 768
* Devices Connected to the Graphics Accelerator *
Active Digital Televisions: 1
* Digital Television *
Monitor Name: Generic PnP Monitor
Display Type: Digital
Gamma Value: 2,2
DDC2 Protocol: Supported
Maximum Image Size:
Horizontal: 27,56 inches
Vertical: 15,75 inches
Monitor Supported Modes:
720 by 480 (60 Hz)
1920 by 540 (50 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Not Supported
Raw EDID:
00 FF FF FF FF FF FF 00 4D D9 01 00 01 01 01 01
32 0F 01 03 80 46 28 78 0A 0D C9 A0 57 47 98 27
12 48 4C 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 01 1D 80 D0 72 1C 16 20 10 2C
25 80 DF A4 21 00 00 9E 8C 0A D0 8A 20 E0 2D 10
10 3E 96 00 DF A4 21 00 00 18 00 00 00 FC 00 53
4F 4E 59 20 54 56 0A 20 20 20 20 20 00 00 00 FD
00 30 3E 0E 2E 08 00 0A 20 20 20 20 20 20 01 48
02 03 21 77 4D 94 03 04 12 13 05 01 07 16 15 11
06 02 23 09 07 07 83 01 00 00 66 03 0C 00 20 00
80 01 1D 00 72 51 D0 1E 20 6E 28 55 00 DF A4 21
00 00 1E 8C 0A D0 90 20 40 31 20 0C 40 55 00 DF
A4 21 00 00 18 01 1D 00 BC 52 D0 1E 20 B8 28 55
40 DF A4 21 00 00 1E 01 1D 80 18 71 1C 16 20 58
2C 25 00 DF A4 21 00 00 9E 8C 0A D0 90 20 40 31
20 0C 40 55 00 30 A4 21 00 00 18 00 00 00 00 68
* Other names and brands are the property of their respective owners. *
I even tried to make a 1920x540 custom resolution using intel's control panel but it says the value i've entered it's incorrect. works when i put 50hz though, but then the screen goes blank.. pls tell me what to do to fix it!!
Marcos_U_Intel
I do notice from the diagnostic report that you do not have the monitor drivers installed.
I recommend to contact your monitor manufacturer for the latest drivers, and if the issue persists test another monitor.
Michael
This is not a monitor but a Sony Bravia TV. From what I see sony have not release any drivers for pc so what else can I do to fix it?
Marcos_U_Intel
At this point I recommend not to use any kind of video adapters or splitters if you are using any, and also to test another monitor or TV.
Michael
ROBERT_U_Intel
Hi John
From the diagnostic report you attached I see that the Intel HD Graphics driver version you are using is 2279. Would it be possible for you to try the latest version from Intel available http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=21428&lang=eng&OSVersion=Windows%207%20(32-bit)*&DownloadType=Drivers here and report your results?
