22884 Discussions
Intel HD 4000 VGA,VGA full range RGB
JJ6
Hi, I have i big question. I read a lot of topic an discuss about Intel and full range settting for video output in 0-255 RGB. I tried edid modification, registry modification, but nothing works.
So what I am asking for..
I have notebook with two video outputs VGA and HDMI. Notebook display is disabled now. I have two exactly same monitors Dell U2414H. Both connected by HDMI, but from VGA output is used simply VGA-to-HDMI digitizer. Everything for good, pc detect from HDMI output exactly Dell monitor (as digital TV), but from VGA it detects firstly digitizer like Monitor VGA to HDMI (Generic PNP display). (I tried to use exactly display driver of Dell U2414H for this vga output display, but not work.
Problem is that monitor throught HDMI is working properly in full range RGB 0-255, by madVR levels tweaker. But display througt VGA not, it it visible that is limited range 16-235. I would like to help how to get into working state, that both video outputs will work in full range RGB 0-255.
Adapter VGA to HDMI supports HDCP, resolution up to 1080p.
Maybe it is problem by Intel drivers, but it should be good to solve it.
Intel driver is latest 15.33.39.4276 (10.18.10.4276). Windows 10 x64, graphics Intel HD 4000.
Thanks in advance, I hope that community will help me and also to other peoples which have same problem.
JJ6
here is the system information:
Intel(R) HD Graphics 4000
Report Date: Sunday, January 10, 2016
Report Time [hh:mm:ss]: 10:06:35 AM
Driver Version: 10.18.10.4276
Operating System: Windows* 10 Pro Insider Preview (10.0.10586)
Default Language: Czech (Czech Republic)
Installed DirectX* Version: 12.0
Supported DirectX* Version: 11.0
Shader Version: 5.0
OpenGL* Version: 4.0
OpenCL* Version: 1.2
Physical Memory: 16273 MB
Processor: Intel(R) Core(TM) i7-3632QM CPU @ 2.20GHz
Processor Speed: 2195 MHz
Vendor ID: 8086
Device ID: 0166
Device Revision: 09
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 4000
Video BIOS: 0.0
Current Resolution: 1920 x 1080
* Devices connected to the Graphics Accelerator *
Active Displays: 2
* Monitor *
Display Type: Analog
Serial Number: BNQ7825
DDC2 Protocol: Supported
Gamma: 2,2
Connector Type: VGA
Device Type: Monitor
Maximum Image Size
Horizontal Size: 20,87 inches
Vertical Size: 11,81 inches
Supported Modes
640 x 480 (60p Hz)
640 x 480 (75p Hz)
720 x 400 (70p Hz)
800 x 600 (60p Hz)
800 x 600 (75p Hz)
832 x 624 (75p Hz)
1024 x 768 (60p Hz)
1024 x 768 (75p Hz)
1152 x 870 (75p Hz)
1152 x 720 (60p Hz)
1280 x 1024 (60p Hz)
1280 x 960 (60p Hz)
1280 x 1024 (75p Hz)
1280 x 720 (60p Hz)
1600 x 900 (60p Hz)
1680 x 1050 (60p Hz)
1920 x 1080 (60p Hz)
Power Management Support
Active Off Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 09 D1 25 78 45 54 00 00
24 12 01 03 68 35 1E 78 2E 60 81 A6 56 4A 9C 25
12 50 54 A5 6B 80 71 00 81 C0 81 40 81 80 A9 C0
B3 00 D1 C0 01 01 02 3A 80 18 71 38 2D 40 58 2C
45 00 13 2B 21 00 00 1A 00 00 00 FF 00 30 30 30
30 30 30 30 30 53 4C 30 0A 20 00 00 00 FD 00 32
4C 18 53 11 00 0A 20 20 20 20 20 20 00 00 00 FC
00 56 47 41 20 54 4F 20 48 44 4D 49 20 20 00 86
* Digital Television *
Display Type: Digital
Serial Number: DELa0a4
Gamma: 2,2
Connector Type: HDMI
Device Type: Digital Television
Maximum Image Size
Supported Modes
640 x 480 (60p Hz)
640 x 480 (75p Hz)
720 x 400 (70p Hz)
720 x 576 (50i Hz)
720 x 480 (60i Hz)
720 x 480 (60p Hz)
720 x 576 (50p Hz)
800 x 600 (60p Hz)
800 x 600 (75p Hz)
1024 x 768 (60p Hz)
1024 x 768 (75p Hz)
1152 x 864 (75p Hz)
1280 x 720 (60p Hz)
1280 x 720 (50p Hz)
1600 x 1200 (60p Hz)
1600 x 900 (60p Hz)
1920 x 1080 (60i Hz)
1920 x 1080 (50i Hz)
1920 x 1080 (50p Hz)
Standby Mode: Supported
Suspend Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 10 AC A4 A0 4C 54 50 33
1C 19 01 03 80 35 1E 78 EE 7E 75 A7 55 52 9C 27
0F 50 54 A5 4B 00 71 4F 81 80 A9 C0 A9 40 D1 C0
01 01 01 01 01 01 02 3A 80 18 71 38 2D 40 58 2C
45 00 0F 28 21 00 00 1E 00 00 00 FF 00 39 54 47
34 36 35 37 36 33 50 54 4C 0A 00 00 00 FC 00 44
45 4C 4C 20 55 32 34 31 34 48 0A 20 00 00 00 FD
00 38 4C 1E 53 11 00 0A 20 20 20 20 20 20 01 4E
02 03 1F F1 4C 90 05 04 03 02 07 16 01 14 1F 12
13 23 09 07 07 65 03 0C 00 10 00 83 01 00 00 02
3A 80 18 71 38 2D 40 58 2C 45 00 0F 28 21 00 00
1E 01 1D 80 18 71 1C 16 20 58 2C 25 00 0F 28 21
00 00 9E 01 1D 00 72 51 D0 1E 20 6E 28 55 00 0F
28 21 00 00 1E 8C 0A D0 8A 20 E0 2D 10 10 3E 96
00 0F 28 21 00 00 18 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 37
* Other names and brands are the property of their respective owners.
JJ6
Still nobody does not know? I know that problem with drivers are in big amount, but I am not developer so I do not see inside the drivers perfectly.
Amy_C_Intel
Hello, JakubJ:
Bear in mind that VGA adapters are not supported, Intel always recommends to use straight connections. Note that you are using an adapter to convert an analog signal to a digital one, when converting this signal you might be losing the chance for the VGA to recognize T.V properly.
Amy.
JJ6
Thank you. Yes.
But why drivers are sending to VGA port limited range of RGB? My point is not to recognize monitor like digital TV, but set color to full RGB space.
I can use DisplayLink adapter, but it is not good solution, so VGa apdter works very well, but Intel driver send incorrect RGB range).
So I am asking if is some unusual way how to change the signal format.
Amy_C_Intel
Full Range RGB support is available for the following Intel® Iris™ and HD Graphics products;
  • 4th Generation Intel® Core™ Processors with Intel® Iris™ Pro Graphics 5200
  • 4th Generation Intel® Core™ Processors with Intel® Iris™ Graphics 5100
  • 4th Generation Intel® Core™ Processors with Intel® HD Graphics 5000/4600/4400/4200
  • 3rd Generation Intel® Core™ Processors with Intel® HD Graphics 4000/2500
  • Intel® Pentium® Processor 2020M/2030M/2117U/2129Y/2127U/A1018/G2010/G2020/G2020T/G2030/G2030T/G2100T/G2120/G2120T/G2130/G2140 with Intel® HD Graphics
  • Intel® Pentium® Processor 3560Y/3556U/3550M/G3220/G3220T/G3320TE/G3420/G3420T/G3430 with Intel® HD Graphics
  • Intel® Celeron® Processor 927UE/1000M/1005M/1007U/1017U/1019Y/1020E/1020M/1037U/1047UE/G1610/G1620/G1620T/G1610T/G1630 with Intel® HD Graphics
  • Intel® Celeron® Processor 2980/2955U/2950M with Intel® HD Graphics
You should have full range RGB on VGA but with straight connections.
For further reference go to post # 60.
JJ6
Yes Amy, this works very well and I tried it earlier, but RGB for normal desktop mode not. There is visible limited range.
VGA is connected throught adapter.
Amy_C_Intel
Have you check with straight connections(VGA-VGA)? Like mentioned before VGA adapters are not supported from our end.
JJ6
Dell U2414H has no option for VGA - only HDMI, displayport.. But when I connected another monitor (older) VGA-VGA, then it is probably ok/same view, because that monitor is not IPS and black is not exactly black. So I cannot recognise if it is FullRGB.
Amy_C_Intel
I understand but from our documentation full range RGB is supported with straight connections, we cannot confirm that you will get full range since you are using an unsupported adapter.
