22988 Discussions
Intel HD 4400 shows that only OpenGL 1.1 available (Windows 8.1)
CSelm
My desktop computer is running Windows 8.1 with an Intel Core i3-4160 processor (HD 4400 graphics). I'm trying to run an application that requires a minimum of OpenGL 2.0, but my computer reports that only OpenGL 1.1 is available. The graphics driver is 10.18.14.4332 (11/20/2015), which is the latest available.
What has to be done to get a minimum of OpenGL 2.0 working?
EstebanA_C_Intel
Hello, Rugen:
I would like you to check the following link that contains the APIs and features supported by the different Intel® HD Graphics.
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005524.html Supported Graphics APIs and Features for Graphics Drivers
Esteban C
CSelm
Yes, I saw that there should be support for OpenGL 4, but yet my computer with the latest driver only has OpenGL 1.1 available. That's my issue.
EstebanA_C_Intel
Hello, Rugen:
Please test your system with the latest generic driver from Intel®.
Do note that if your system is OEM, any special features or settings would not be available while using generic drivers.
Please do make sure you download the driver that matches your system (32/64-bit)
https://downloadcenter.intel.com/download/25588/Intel-Graphics-Driver-for-Windows-7-8-1-15-36- Download Intel® Graphics Driver for Windows 7/8.1* [15.36]
If this is not working and you have an OEM system, they way to go would be to download and install the drivers directly from your manufacturer's website.
Esteban C
CSelm
That's the same driver that I currently have installed. The download and beginning of the installation call it 15.36.28.4332, but the last couple of steps of the installation swap to calling it 10.18.14.4332.
The system is a custom-build with a MSI motherboard. I've tried the latest driver from MSI as well with no luck.
EstebanA_C_Intel
Hello, Rugen:
I would like to recommend you to check the following article related to OpenGL access.
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005575.html How to Access OpenGL* and DirectX* 3D Settings for Graphics Drivers
Esteban C
