23818 Discussions
Intel HD 4600 Graphics blurry text
LP
Intel HD 4600 in Windows 10, text and some icons are blurry in some applications but not in all of them. For example in device manager window the text and icons are blurry.
Already tried cleartype changes but nothing seems to work! Is there a solution for this issue?
Hi LPV,
Your system has hybrid graphics; please tell me did you build the computer or it is pre-build?
If you have the second case, make sure you have the latest BIOS and drivers from your system manufacturer.
In the case of custom build, let me know motherboard model, processor model and memory specs.
Miguel C
LP
Hi Miguel,
Thanks for your answer. My system is pre-build. Is a Toshiba Satellite P50-B-11V.
I've all the latest drivers and BIOS.
Intel HD 4600 Graphics driver version: 20.19.15.4360
AMD Radeon R9 M265X driver version: 15.201.1101.0
KKost3
Try to set Windows Scalling to 100%, you probably have now something like 125%
LP
Hi Kostek,
Brilliant! Indeed solved the problem..that never crossed my mind.
Thanks!
Hi LPV,
I am glad your system is running properly now.
Kostek,
Thank you for your suggestion.
Mike C
