23801 Discussions
Intel HD 4600 - graphic bug
cDavi13
Hello world,
When I use integrated HD Graphics 4600 to play Microsoft Train Simulator (old game in english from 2001 patched 1.4), it gets some texture problems like this.
(same problem like another player at http://forums.uktrainsim.com/viewtopic.php?f=237&t=134976&start=0&st=0&sk=t&sd=a http://forums.uktrainsim.com/viewtopic.php?f=237&t=134976&start=0&st=0&sk=t&sd=a)
Is there a way to launch this game without graphic bug ?
Configuration : Windwos 7 64 bit
intel i7-4770k with last graphic driver 10.18.10.3345
The BIOS of my motherboard (ASUS Z87-PLUS C2) is update with last version.
Thanks !
Allan_J_Intel1
Hi Davilex,
I see this game is compatible for old operating system versions and some other requirements that are met with your new system however, the problem might be related due to compatibility with your operating system version \
See here for system requirements:
http://www.ehow.com/facts_5202346_microsoft-train-simulator-requirements.html http://www.ehow.com/facts_5202346_microsoft-train-simulator-requirements.html
http://www.allgame.com/game.php?id=27666&tab=sysreqs http://www.allgame.com/game.php?id=27666&tab=sysreqs
Allan.
cDavi13
Thank for your response.
However, this post seems indicate that it is possible to run this game under Windows 7.
http://msts.steam4me.net/tutorials/installing_msts_w7.html# install Installing MSTS On A Windows 7 PC - at The Steam4me Site
For the moment, i have no graphic card in my system.
So, the only choice is to wait for a release of Intel graphic driver (january 2014 ?) or to buy a graphic card.
Christophe.
HJaco2
I have the same problem running the old MS Train Simulator on a new laptop.
Indeed. Following the steam4me intructions, MSTS usually works fine on Windows 7 and 8 (without Intel Graphic)
MSI CR70-2M-P345W7
Intel Pentium CPU 3550M 2,3GHz
4 GB
Windows 7 Home Premium 64 bit SP1 all at Christmas from MS available Updates are installed.
Intel Hardware Test says:
Graphics Driver (Newer Driver Available)
Product Detected Intel® HD Graphics for Intel® Pentium® and Celeron® Processors with Intel® HD Graphics
Current Driver Installed 9.18.10.3186
Newer Driver Available: 15.33.8.64.3345 (10.18.10.3345)
Download Now
(Driver is updated now)
In this forum
http://www.trainsim.com/vbts/showthread.php?317237-Problem-with-MSTS-on-Win-7-%2864%29 http://www.trainsim.com/vbts/showthread.php?317237-Problem-with-MSTS-on-Win-7-%2864%29
was said, with OLD drivers on Intel Graphic chips MSTS works ...
But where to find older drivers?
cDavi13
Old drivers can be found here : http://www.touslesdrivers.com/index.php?v_page=26&v_code=379&v_ordre=0&v_systeme=166&v_type=1 http://www.touslesdrivers.com/index.php?v_page=26&v_code=379&v_ordre=0&v_systeme=166&v_type=1
03/10/13 - drivers 15.31.19.64.3293 bêta pour Windows 7-64/8-64/8.1-64
13/09/13 - drivers 15.31.17.64.3257 WHQL pour Windows 7-64/8-64
30/07/13 - drivers 15.31.9.64.3165 WHQL pour Windows 7-64/8-64/8.1-64
06/06/13 - drivers 15.31.9.64.3165 WHQL pour Windows 7-64/8-64
07/04/13 - drivers 15.31.3.64.3071 WHQL bêta pour Windows 7-64/8-64
And now, this is the "response" of Intel support about this problem...
Good luck for installations of old drivers...
"{ticketno:[8000845066]} - Your Intel Customer Support Inquiry
Hello Christophe,
Thank you for contacting Intel Customer Support.
I understand letters appear in Microsoft Train Simulator when you try to play it.
I recommend making sure you have the latest patches installed for that game.
You can also try using previous version of the graphics driver. You can uninstall the current version from Programs and Features in Control Panel and then reinstalling the driver from this link
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23405&lang=eng" target="_blank" data-mce-href="https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23405&lang=eng">https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23405&lang=eng
I recommend also contacting Microsoft in order to make sure they have validated the game for Intel HD 4600."
