23771 Discussions
Intel HD 530 Graphics drivers
KReal1
I am having issues with the most recent W10 1709 updates and running two external monitors.
The two monitors both worked prior to the most recent updates, but since the updates and running driver 21.20.16.4550 I have issues on restart where the device shows issues in the device manager and does not work. I can sometimes re-install the drivers and get things running, but other times the system will only run one of the monitors from the HDMI port, while the USB port does not detect a monitor.
If I run check for updates from device manager the system installs driver 22.20.16.4836, which does not detect a monitor from the USB port, and only runs the monitor from the HDMI.
My machine details are below, and all of the updates and drivers are current, so it seems Lenovo may not have identified this issue yet as the recommended driver does not work with these latest updates.
Has anyone experienced similar issues or found a driver that will work with the recent updates and two external monitors?
Thanks in advance,
K
Computer
LENOVO 80NV
Operating System
Microsoft Windows 10 Pro (64-bit)
Version
1709
OS Build
10.0.16299
Build Branch
rs3_release
Locale
English (United States)
Windows Directory
C:\WINDOWS
System Directory
C:\WINDOWS\system32
.NET Framework Versions
2.0.50727.4927, 3.0.30729.4926, 3.5.30729.4926, 4.0.0.0, 4.7.02556
Default Internet Browser
Internet Explorer 11.192.16299.0
Installed Internet Browsers
Mozilla Firefox, Google Chrome, Internet Explorer 11.192.16299.0
Processor
Intel® Core™ i7-6700HQ CPU @ 2.60GHz
NVIDIA GeForce GTX 960M
Adapter Compatibility
NVIDIA
Video Processor
GeForce GTX 960M
Driver Provider
NVIDIA
Driver Version
22.21.13.8264
Driver Date
6/18/2017
Adapter DAC Type
Integrated RAMDAC
Adapter RAM
4.00 GB
Availability
Offline
Status
This device is working properly.
Location
PCI bus 1, device 0, function 0
Device Id
PCI\VEN_10DE&DEV_139B&SUBSYS_380217AA&REV_A2\4&3807D8BA&0&0008
Intel® HD Graphics 530
A customized computer manufacturer driver is installed on your computer. The Intel Driver & Support Assistant is not able to update the driver. Installing a generic Intel driver instead of the customized computer manufacturer driver may cause technical issues. Contact your computer manufacturer for the latest driver for your computer.
Intel Corporation
Video Processor
Intel® HD Graphics Family
Resolution
1920 x 1080
Bits Per Pixel
32
Number of Colors
4294967296
Refresh Rate - Current
60 Hz
Refresh Rate - Maximum
60 Hz
Refresh Rate - Minimum
60 Hz
Driver Provider
Intel Corporation
Driver Version
21.20.16.4550
Driver Date
11/11/2016
Adapter DAC Type
Internal
Adapter RAM
1.00 GB
Availability
Running at full power
Status
Location
PCI bus 0, device 2, function 0
Device Id
PCI\VEN_8086&DEV_191B&SUBSYS_380217AA&REV_06\3&11583659&0&10
Stefan3D
Try drivers from this list https://downloadcenter.intel.com/product/88345/Intel-HD-Graphics-530 Downloads for Intel® HD Graphics 530
Select OS from right pull-down menu. Hit "show more".
To bypass message "best driver is already installed", "customized computer manufacturer driver" or "computer is not validated" install driver via have disk method as described at:
https://www.windowscentral.com/how-install-intel-beta-graphics-drivers-surface https://www.windowscentral.com/how-install-intel-beta-graphics-drivers-surface (ignore prolog about MS surface)
KReal1
Thank you Stefan, but unfortunately this did not work. I have a 64-bit machine and the recommended driver - 15.60.2.4901 does not work with two monitors.
Hello Kreal,
I understand that you are having problems to run 2 monitors at the same time, I apologize for any inconvenience.
I was checking the information sent by you and I can see that you also have a dedicated video card. According to the details the driver of that video card is not yet updated. Please check the following link:
http://www.nvidia.com/download/driverResults.aspx/130637/en-us http://www.nvidia.com/download/driverResults.aspx/130637/en-us
"Please be aware that the content on that site is not controlled by Intel*. This information is offered for your convenience and should not be viewed as an endorsement by Intel* for the merchants or services offered there."
I hope you find this helpful.
David V
KReal1
Thank you David, I have updated the Nvidia driver, and then attempted to install the recommended driver 15.60.2.4901 but immediately one of the monitors stopped so I rolled back the intel driver to 21.20.16.4550, which brought the monitor back on.
Additionally, on the OS my details are below.
Thank you for the assistance.
  • Version1709
  • OS Build10.0.16299
  • Build Branchrs3_release
  • LocaleEnglish (United States)
  • Windows DirectoryC:\WINDOWS
  • System DirectoryC:\WINDOWS\system32
  • .NET Framework Versions2.0.50727.4927, 3.0.30729.4926, 3.5.30729.4926, 4.0.0.0, 4.7.02556
  • Default Internet BrowserInternet Explorer 11.192.16299.0
  • Installed Internet BrowsersMozilla Firefox, Google Chrome, Internet Explorer 11.192.16299.0
Stefan3D
...I rolled back the intel driver to 21.20.16.4550, which brought the monitor back on...
Try 21.20.16.4821 from https://downloadcenter.intel.com/download/27227/Intel-Graphics-Driver-for-Windows-15-45-?product=88345 Download Intel® Graphics Driver for Windows* [15.45]
It is the same driver branch.
KReal1
Thank you Stefan. I installed 4821 and had similar problems. Initially everything worked fine with both monitors, but on restart there were issues which required hard restarts and eventually after logging in the device was not working properly. I have gone back to 4550 and appreciate any further recommendations or assistance in finding a compatible driver.
Hello Kreal,
Thank you for your responses,
I was checking some details and I would like to know if you have tried checking under "Graphics Properties" and then select "Multi-monitor"? This is to check and see if both monitors show there or only one.
If both show there then it is important to configure them from there by either selecting clone or extend. Once this is done, both of the displays should show and be on. Let me know the outcome please.
David V
Hello Kreal,
I am following up with your case and see that we have not heard back from you.
If you need more assistance do not hesitate to reply.
David V
KReal1
Hi David,
My apologies, but it appears as though my response didn't post correctly. When I checked with the recommended drivers from this thread and in Graphics properties only one monitor was showing, even when I attempted to detect additional monitors.
Thank you for your assistance with this and please let me know if I can provide any additional details which may assist in diagnosing the issue.
K
Hello Kreal,
Thank you for your response,
I was checking some information about the system and the different details you have provided and I was able to see that you are using a USB port to get image. That configuration is not supported since the video signal should be via HDMI, Display Port or USB-C.
Also, this issue seems to be more related to hardware limitations since there is only one extra HDMI port and in this kind of configuration it would only take the built-in monitor plus the extra monitor via HDMI.
David V
KReal1
Thank you all for the assistance.
I believe I have found the issue, which was related to another graphics driver - Trigger External Graphics Family, which I found in my programs. This driver seems to have been related to Magix Movie Edit. While everything was previously running fine with 2 monitors, one from HDMI, and the second from USB, it seems that the January W10 1709 updates triggered conflicts between the Intel/ NVIDIA, and this Trigger driver which must have installed with the Movie edit program.
I have now uninstalled the Trigger driver, and everything seems to be working as it should and no further problems running the two monitors or restarting the machine as normal.
Thank you all again for the help, and hopefully this thread will assist any others who may run into similar issues.
Cheers,
K
zaynsal
Hello, @idata @VARADHARAJAN @Leonardo_C_Intel  I tagged you guys and I m sure you could help me with this issue
I have an issue that my screen laptop just crashed + turned off and restart again directly when or after login the windows. However, I can get into the safety mode and disable the Graphics 530 and reboot into regular mode, then it works properly, but the feedback is nonadjustable brightness of screen. My laptop has a GTX965m and an Intel Graphics 530. I also get latest windows update
and bios update. I've tried a lot of version of driver, includes the recommended version from my "Multi-com" Laptop and last updates on windows but its happen even if I  installed from there . By the way, this problem happen a year ago and I installed windows 11 but still the same issue happen over and over again .
Disable = no brightness adjustment,
Enable = crash and turn off and restart again with no reason when or I m on trying to login the windows couple seconds without doing anything its happen (web, games, etc)
Anyone could help please you ll be my hero for real
Laptop information:
the laptop is multi-com
Intel Core i7-6700HQ
GTX965m / Intel Graphics 530​
System manufacturer:notebook
version 10.0.19045 structure 19045
The manufacturer of the system Microsoft
System name: DESKTOP-RQ9N15H
System model: N15_N17RF1
Type of system : x64-based PC
BIOS version/date: American Mega trends Inc 1.05.02, 01-04-2016
BIOS System Management version of: 3.0
The version of the controller: 255.255
BIOS mode: U.E.F.I
windows information >>
Windows 10 Pro version
Version 22h2
Installed on 29-02-2024
OS architecture 19045.4170
Windows Feature Experience Pack 1000.19054.1000.0
VARADHARAJAN
Valued Contributor II
Its graphics driver ,boot windows into safemode, uninstall  intel graphics driver ,use DDU software  uninstall completely drivers , restart windows , pause windows update , download driver from intel website and install intel graphics driver manually
https://www.intel.com/content/www/us/en/download/762755/intel-6th-10th-gen-processor-graphics-windows.html
