23833 Discussions
Intel HD 530 tearing problem
BBalo
Hello
I have i5 6400T CPU with an integrated Intel HD 530. I am using Windows 7 Home Premium x64 operating system with latest graphic drivers, version 20.19.15.4352. There is a very noticeable tearing when playing video online, in the browser, e.g. on YouTube. ( https://www.youtube.com/watch?v=5xkNy9gfKOg tearing test @29.97 fps (1080p) - YouTube )
If I set Vertical synchronization (VSync) in graphic drivers option to "On", it has no effect.
I found out that if you use Aero in Windows, there will be no tearing, because it will enable "Desktop Window Manager" which utilize methods to prevent it. I can remove tearing in media player with its own VSync, but obviously no such option exist in an internet browser.
I find this very limiting, as I do not want to be forced into using Aero. On my previous system I had the same non-Aero theme with an integrated AMD GPU and there was no tearing, so it would seem it is a driver issue.
Is it possible this will be fixed in the next driver update?
Thank you.
MZ3
I am using a Pentium G4440 with HD 510 (also Skylake).
I have similar problems with the iGPU and started a thread a shortly before you.
I am total unhappy with the decision to go with the Intel iGPU so far
Cesar_B_Intel
Hello Balo.
Could you please provide us with the information from in order to attempt to reproduce the issue?
Also the http://www.intel.com/content/www/us/en/support/graphics-drivers/000005848.html?wapkw=graphics+driver+report Intel® Graphics Driver Report for Graphics Drivers
Post the requested information here.
Caesar B_Intel.
BBalo
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
Screen tearing ( https://en.wikipedia.org/wiki/Screen_tearing https://en.wikipedia.org/wiki/Screen_tearing )
Does it fail every single time, or only sometimes?
If you can offer a % rate please do.
Frequency of tearing depends on the nature of the video content and is usually visible when panning..
Hardware (HW)
Brand and Model of the system.
Intel Skylake HD Graphics 530
Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?
No other GPU.
Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)
EFP = External Flat Panel (Monitor you plug in)
EIZO EV2436WFS LCD via DVI, attachments for further info
How much memory [RAM] in the system (see note2 below).
16GB DDR4
Provide any other hardware needed to replicate the issue.
ie: Cables&brand, cable type [vga, hdmi, DP, etc], dock, dongles/adapters, etc
N/A
<p style="margin-b...
Cesar_B_Intel
Hello Balo,
Thank for providing this information.
I will proceed to investigate on this issue and will let you know of the results.
Caesar B_Intel.
BBalo
Hello, any progress here?
Cesar_B_Intel
HelloBalo
Thanks for asking, we are still investigating this issue and as soon as we have any updates we will let you know.
Caesar B_Intel.
bdara
hello i'm user from thailand
my problem is similar this topic
i have no vga card.
very tearing when play on youtube but never found in play game such as Dota2
i tried 2 browser are Chrome and Firefox but problem not gone
i tried reinstall and add extention is Disable html 5 on Chrome browser but problem not gone
i tried uncheck Hardware Acceletor on Chrome browser but problem not gone
my system is
i5 6400
gigabyte h170n wifi
kingston hyper x fury ddr4 2133 8 gb (4x2)
kingston hyper x fury ssd 120 gb
silverstone PSU 450w (gold 80+) st450f-g
i very unhappy please support me
thank you
mailto:[email protected] [email protected]
EstebanA_C_Intel
Hello, All:
I would like to check what is the behavior of your system while using the latest drivers available for Intel® HD Graphics 530
Found here: https://downloadcenter.intel.com/download/25848/Intel-Beta-Graphics-Driver-for-Windows-7-8-1-10-15-40-?product=88345 Download Intel® Beta Graphics Driver for Windows® 7/8.1/10* [15.40]
Additionally, you could test you system using different cables, different monitors and different video output, as well as straight connections to discard an adapter as the source of the issue.
I look forward to your reply on this.
Esteban C
bdara
i tried install beta version follow your link but cant fix tearing youtube
but not change hdmi cable now
this monitor is ok cause i tried test other system it not happen tearing when play youtube
EstebanA_C_Intel
Hello, All:
I would like to request some additional information about your system to better understand this scenario.
Please provide me with the information requested here:
I look forward to your reply.
Esteban C
BBalo
I have tried latest beta and non-beta drivers, but the tearing problem is still there.
I have not enabled Aero theme, as installer asked, I did explain this in my original post.
EstebanA_C_Intel
Balo:
I can see that the Intel® Core™ i5-6400T Processor is a tray only processor, which means that it is to be used by OEMs.
For that reason, have you tested the behavior of your system with the drivers provided by your OEM? If not please provide me with the model of your device so I can provide you with the download links.
There is a tool (Intel® System Support Utility) that can allow you to create a report (which has the information I need) with a few clicks.
Intel® System Support Utility download link: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Download Intel® System Support Utility
I look forward to hearing from you.
Esteban C
bdara
Hello guy
my tearing problem on youtube (html5) is gone!!
I not sure why happen because i not change anything!!
1 thing I do just update Intel(R) Update Driver Utility to 2.4 version
and I scan for new update found lasted version is Proset/Wireless and graphic Driver update
but I not install them
and I open youtube for listen same music
I found tearing is gone!!
I very confuse
timeline of tearing gone
1.I bought new extension lead is Panasonic WCHG28352 (old is anitech brand is cheaper)
2.I update Intel(R) Update Driver Utility to 2.4 version
3.I open youtube for listen same music (https://www.youtube.com/watch?v=T_4RvW2zFww แพ้ทาง - LABANOON「Official MV」 - YouTube) I found tearing is gone!!
4.I think cause extension lead I swap to old but problem is gone too!!
I dont know why happen to me
EstebanA_C_Intel
Hello:
I am glad to hear that this is not happening.
I would like to know what is the driver version you are currently using for other users to test the behavior of the system with that driver.
How to check driver version: Windows key + R and type "dxdiag" and then go to display tab and check the driver available.
Esteban C
bdara
EstebanA_C_Intel
Hello, go6dad:
Thank you for providing us with that information, for sure this is going to be helpful for future users that could face this scenario.
If any additional questions or inquiries are present, feel free to contact us back.
Esteban C
MBish4
Hi All.
We have had exactly the same problem. I deployed Win7 to a Hp Prodesk 400 G2 with the latest drivers off the HP website and had horrible screen tear on 720p+ videos on YouTube.
The solution for us was rolling back to an old driver. I can confirm we have tried 10.18.15.4279 on Win 7 and 10.18.15.4256 on Win 10 (out of the box) and this has resolved the issue for us 100%. No more screen tearing.
Hope this helps someone.
EstebanA_C_Intel
Thank you for your input on this mjb1505 it is for sure useful for some other users with a similar configuration.
Balo, I was wondering if you were able to get the report from your system in order to further assist you on this.
Esteban C.
BBalo
I bought this CPU separately and used it in my own build.
I think I already generated report with that tool before, it should be on the previous page.
I wonder if go6dad or mjb1505 could verify if there is no tearing using test video from my original post. Degree of screen tearing might vary, but that one should be a good indicator.
I tried 10.18.15.4279 version of drivers and there still was some noticeable tearing.
I should mention again, this applies for non-Aero environment.
MBish4
Hi Balo.
With regards to my previous comment I need to revise what I have said. We have since found that the machines in question, all identical in spec, work fine with the driver mentioned with the preinstalled (hp branded) version of Windows 7. However, when we deploy our build (using MDT) of windows 7, even with every driver being exactly the same as on the hp copy of windows, we get the same tearing problem. We can't find any logical reason for this. We have even ripped the drivers off the original install (annoyingly the driver disk provided had different versions from the ones installed) and have not been able to replicate the initial flawless experience.
My comments on windows 10 remain unchanged. On all 3 of the 10 machines we have tested windows 10 works flawlessly out of the box (after waiting a little while for it too install the Intel driver over the windows basic graphics driver it uses on first boot)
We have therefore decided to push forward our rollout of Win10 by using these 10 machines as out first phase. Annoying as it is we are unable to justify spending any more time trying to resolve the issue in Win7 when we have a viable alternative solution.
