23833 Discussions
Intel HD 620 Graphics No HDMI Input
Mattjn82
I have a Gigabyte brix gb-bri7h-8550 i7 barebone system with the Intel HD 620 integrated graphics. It was happily using extended display using HDMI and display port for over a year then one day the extended display stopped working. Now the monitor on HDMI port will not display when booting into windows. The boot screens display ok but as soon as windows starts it stops and goes to the display port screen. Strangely both monitors are detected in windows and you can change which monitor is 1 or 2 etc. I have checked the settings for extended display and also tried different resolutions and refresh rates for the screens.
I have tried uninstalling and reinstalling the graphics driver to the latest version. All windows updates have been done. I have even tried upgrading to windows 11 over the top of 10 but still the same issue remains. If I leave the graphics as the basic driver the HDMI screen works so it is an issue with windows not allowing the HDMI to display with the Intel graphics driver.
My last resort is wiping the machine clean and doing a clean install but I do not want to have to do this as its a pain reloading everything and I have a second machine (identical hardware) doing the same thing. We have 11 of these computers so if they all get this issue at some point I do not want to have to reload from scratch for each one.
I have also used a restore point before a windows update once this issue started and the problem still remained.
Has anyone had a similar issue and found a solution without having to reload windows from scratch?
Thanks in advance for any help.
David_G_Intel
Hello Mattjn82
Thank you for posting on the Intel️® communities. Based on the troubleshooting provided, this doesn't seem to be an issue with the graphics or drivers. Since this is a Gigabyte PC you have to check with them first for hardware/software support or check with Microsoft if the issue could be related to the OS. We can only recommend driver updates or versions but you already tried that.
David G
Alx24
New Contributor II
Multi-monitor configuration settings are stored in the Windows registry and are used by Windows Display Manager. Microsoft Corp. can tell you how to repair it.
Alx24.
Alx24
New Contributor II
You can always use internal universal "Microsoft Basic Display Driver" of Windows for simple testing without radical update main driver.
Alx24.
Mattjn82
Thank you for your replies.
The HDMI screen works with Windows Basic Drivers, but you cannot use extended displays with it.
As soon as I install any version of the graphics driver the HDMI screens stops working again but the display port screen always works.
It seems something to do with the driver and windows not allowing the HDMI port to get a input signal even though it works with basic drivers.
Windows knows the second screen it there when the driver is installed just has no input. I have tried different monitors and HDMI cables too.
megan3000
Valued Contributor I
And which driver did you install?
For pre built systems I never use the Intel drivers... I prefer to use those from my maker... (just that's what I like)...
I would say to complete uninstall the driver and install the one from Gigabyte... I'm not sure if this is the one (I found it using what I believe the system model is but you mixed CPU model there...)
[23.20.16.4849]
Megan ❤
Mattjn82
Hi Megan,
Thank you for your reply. I have tried the Gigabyte drivers but I will try again after removing the current ones with the DDU program.
I will let you know how it goes 🙂
Alx24
New Contributor II
Specialized device drivers perform a limited number of functions
management of specialized equipment and everything else is performed
at the operating system level, for example, coordinating the work of several graphics
adapters and monitors.
If you use the windows program regedit.exe you can see the related
control information in sections
Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\GraphicsDrivers
Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\GraphicsDrivers\Configuration
Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\GraphicsDrivers\Connectivity
Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\GraphicsDrivers\ScaleFactors
Designations like
"VSC5138VSY210300165_03_07E5_E1^77EF60D70B7DB48DC5F5E4F5F08F3647"
"GSM000116843009_01_07DB_E2^EAAC0E9D4A87264C055076246FC4A8BA"
"SAM01E5HMEYC02628_33_07D5_B1^7D97A56C2B69324B7B1F51E8625B82CB"
correspond to the displays and are formed from the EDID of the display transmitted to the computer
and in the first case it is the ViewSonic monitor, in the second GoldStar (LG) in the third Samsung
The monitors themselves, as devices are presented in
Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\DISPLAY
for species names
VSC5138
GSM0001
SAM01E5
There is also their EDID, which before Windows 11 was represented by one 128 bytes block and in Windows 11 completely
Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4d36e968-e325-11ce-bfc1-08002be10318}
Class Display
Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4d36e96e-e325-11ce-bfc1-08002be10318}
Class Monitor
Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\DeviceClasses
DeviceClasses
Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\BasicDisplay
Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\igfxCUIService2.0.0.0
Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\igfxLP
Drivers and modules are digitally signed so their uncontrolled invisible changes are unbelievable
the data in the registry is modifiable and from all of the above it follows that to create
the updated display configuration needs to start with easily and completely safely connect other displays and this will create new ones
registry entries that may not contain errors.
The simplest multi-monitor configuration is Clone Mode ( Double ) in which
frame buffer simply carries over to two displays with the same screen resolution. In case of different resolutions
you have to perform calculations to find the best general resolution that leads
to different aspect ratios of image and screen, etc. and much more complex settings
You can display the image only on one of the displays, change the purpose of the monitor.
Device drivers contain .inf files that are copied to
directory C:\Windows\INF
named OEMxx.inf and components are sent to directory
C:\Windows\System32\drivers
At the same time, in a form suitable for subsequent installation, they are also stored in
C:\Windows\System32\DriverStore
C:\Windows\System32\DriverStore\FileRepository
if all driver components are not completely deleted when the driver is uninstalled.
Thus, you can always find the original working drivers originally installed by the system manufacturer.
The sequence of OEMxx.INF numbers and dates reflects the installation sequence of hardware drivers.
For the video adapter, the corresponding file contains the string "Class=Display"
it also contains the names of the modules by which you can find the corresponding folder in
in addition there are also files with the extension LOG
setupapi.setup.log
setupapi.dev.log
setupapi.upgrade.log
The setupapi.setup.log or similar file contains the entire sequence of installing hardware drivers on your computer
including computer manufacturer operations.
Graphics drivers in Windows are among a small number of fairly modern device
and very compact.
Alx24.
Alx24
New Contributor II
Also, the configuration may be absolutely correct but may lack any system resources
( memory, performance for Extended Desktop ) so you can try it at lower resolutions.
Alx24.
Alx24
New Contributor II
In a dual-monitor configuration, if you pull out the cable of one of the displays, it should automatically
switch to the mode of one display - one or the other.
There is "Multiple displays", button "Detect".
Alx24.
Mattjn82
Hi, thank you for your replies.
When i take out the working monitor cable from the display port the screen on the HDMI still does not work. It sees to be something with the HDMI and the graphics driver. it was working fine for over a year then stopped.
The HDMI works if its just windows basic driver but as soon as the graphics driver is installed it stops displaying and says no input.
It is very frustrating.
I have used the DDU program to remove the graphics driver and reinstalled different versions to try but as soon as the driver is on the HDMI stops again.
It seems to be something with windows/graphics driver stopping the HDMI displaying.
Any further help would be appreciated.
Alx24
New Contributor II
You can always take a brand new drive, a disk with enough space for the system, or a partition of the currently used disk and install Windows and any graphics drivers in it and experiment and not affect the running system in any way.
Alx24.
Alx24
New Contributor II
Windows Basic Driver works in a completely different way than a regular display driver, I believe, through the universal very reliable VESA modes of the video card. In this case, you can try to simply connect other monitors through a simple USB-HDMI connector, USB-DisplayPort.
Alx24.
Alx24
New Contributor II
Mini PC GB-BRi7H-8550 has an HDMI 2.0 interface that does not have Intel® Core™ Quad Core i7-8550U ( only HDMI 1.4 )
and is provided by an external LS-Pcon. Here you can also use USB-C - HDMI, USB-C - DisplayPort.
Alx24.
Alx24
New Contributor II
Attachment is here
https://www.gigabyte.com/us/Mini-PcBarebone/GB-BRi7H-8550-rev-10#ov
And Wireless Display Adapter is also possible ( with care ).
Alx24.
Alx24
New Contributor II
In this case, it does not matter at all, but it is worth noting that the HDMI interface also serves to transmit
sound and this can also be paid attention to when connecting a TV or display with an audio channel.
Alx24.
