23799 Discussions
Intel HD Craphics & HDMI connection
i have a huge problem!!
when i plugged in HDMI cable from my LED TV it worked fine, but then i accidently changed some "Hz" Settings from "HD Graphics menu" so now, when i plug in HDMI cable, my screen goes blank and i can't see anything, Sometimes my screen is Flashing, and i noticed than my Windows 7 x64 said this message! "Intel HD Graphics Stopped working".... then i just have to boot my PC and my screen works fine.. So Please help me! i've tried re-installing and configuring.. but my PC <-> LED TV connection is not working correctly! so is there any reset config? downloadable? i give more information from my PC if you need to.
In regards with your inquiry, I recommend you the following:
* Uninstall the Intel graphics driver
* Boot your system with the PnP Windows* graphics driver
* Install the latest driver for your LED TV.
* Install the Intel graphics driver and check it out
* Additionally you may try restoring the BIOS settings of your system.
If you want to try our Intel graphics driver is here:
http://www.intel.com/support/graphics/detect.htm http://www.intel.com/support/graphics/detect.htm
Remember this driver is generic, the one you have in your system installation disk has been customized by your system manufacturer for your equipment.
Dago MC.
