22883 Discussions
Intel HD Graphics 4600 - Red dots/lines with hdmi
MToni
Hi, I bought a new hdmi monitor, and I connected it as second monitor in my motherboard. The problem is that I see red dots and lines (with movement) specially with dark images. I tested the cable with my laptop and works well, so I confirmed that the monitor and the cable are OK. I updated the driver to the lastest version. Could it be a problem of the onboard video card? It's strange because the dvi output works properly with my old monitor. The problem is with the hdmi output, and it happens with both hdmi conectors. My hardware is:
Motherboard: GIGABYTE Z87X-UD5H-CF
Video:
Intel Haswell-DT GT2 - Integrated Graphics Controller [GIGABYTE]
OS: Microsoft Windows 8.1 Professional (x64) Build 9600
Micro: Intel Core i7-4770K (3500.0 MHz)
Best regards
Amy_C_Intel
Hello MTonina,
Could you please check if this 15.36.24.64.4264 is the latest version you have , here is the link in case you don't have it https://downloadcenter.intel.com/download/25232/Intel-Iris-Iris-Pro-and-HD-Graphics-Driver-for-Windows-7-8-8-1-64bit Intel® Download Center.
Amy.
MToni
Hi and thanks for your answer. In fact, that is my version. By the way, I re-installed it from the link that you gave me, but I still have the same problem.
Marcos
MToni
One strange thing that is happening is that when I go to properties of the controller, it says that the version is "10.18.14.4264". I attached a screenshot.
Amy_C_Intel
I can confirm that the 10.18.14.42.64 version you have is the latest Graphics version, for further information http://www.intel.com/support/graphics/sb/CS-020667.htm Graphics Drivers — Understanding The Intel® Graphics Driver Version Number.
Does this issue, the red dots and lines happen when you're in the BIOS?
Could you send us a picture of the issue?
Amy.
MToni
Oh yes. It happens when I'm in the BIOS too.
I attached a screenshot of my desktop.
Marcos
Amy_C_Intel
Marcos, since the error persists on the BIOS it seems that graphics portion on the CPU might be defective, my recommendation is to contact Intel Customer Support to check the warranty options for your Intel Core i7-4770K. You can use our support options to do that.
Support: http://www.intel.com/p/en_US/support/contactsupport http://www.intel.com/p/en_US/support/contactsupport.
Amy.
