23833 Discussions
Intel® HD Graphics 4600
Mkame
Please updates drivers windows 10 32 bit
HRear
My driver keeps stopping and restarting due to it's not responding. I don't understand. Please fix intel. I have windows 10 64 bit.
EstebanA_C_Intel
Hello:
I would like to recommend the following to you:
1. Access the device manager and uninstall the Graphics driver.
2. Restart the system and let Windows 10* install the default graphics drivers.
3. Test the behavior of your system.
If this is an OEM system, the recommendation is to use the drivers directly from the manufacturer of the device.
Intel® drivers for Intel® HD Graphics 4600
Windows 10* 32-bit driver: https://downloadcenter.intel.com/download/25541/Intel-Beta-Graphics-Driver-for-Windows-7-8-1-10-15-40- Download Intel® Beta Graphics Driver for Windows® 7/8.1/10* [15.40]
Windows 10* 64-bit driver: https://downloadcenter.intel.com/download/25489/Intel-Graphics-Driver-for-Windows-10-15-40-4th-Gen- Download Intel® Graphics Driver for Windows® 10 [15.40][4th Gen]
Also, I would like to have a little more detailed explanation of the issue you are having with the drivers used.
I look forward to your reply.
Esteban C
EstebanA_C_Intel
Hello, Mustapha.kamel:
Let's try with this driver: https://downloadcenter.intel.com/download/25541/Intel-Beta-Graphics-Driver-for-Windows-7-8-1-10-15-40- Download Intel® Beta Graphics Driver for Windows® 7/8.1/10* [15.40]
Please let me know if this worked for you.
Esteban C
HRear
HOw do I know which generation intel I have? And will the beta mess with my system?
Mkame
Thanks for the answer EstebanC_Intel
But there are still some problems
EstebanA_C_Intel
Hello:
Mustapha.kamel Which are the problems you are encountering with?
bikermom39 The first number after i# - would indicate the generation of your processor.
Beta drivers are testing drivers before they provide the "release" version of the driver, since this one has some time released, chances are that the driver is working properly for most customer.
Esteban C
HRear
Where do I look up my driver information?
Mkame
EstebanA_C_Intel
Hello:
bikermom39 you can verify that in the device manager, Device Manager>Display adapters>right click on the Intel® HD Graphics and click properties, driver tab is where you will find the driver version installed.
Mustapha.kamel what is causing this freeze or what is happening with the device?
I look forward to your replies.
Esteban C
