23637 Discussions
Intel HD Graphics 520 64 bit
eiesc
I have already installed Autocad 2017, my laptop is an HP Spectre x360 2-in-1, Windows 10, and an Intel HD Graphics 520 64 bit.
The problema is that Autocad 2017 has too many problems with this Intel Product.
Has anyone a solution for this problem? Is the Intel Product compatible with this version of autocad?
Thanks you
Hello kikeles,
Thank you for joining the Intel communities.
I'm sorry you mention that you have a problem with Autocad 2017 but I don't know what the problem is, could you please specify the problem you get when you run Autocad 2017?
Also, I will appreciate if you could download and run the Intel SSU (System Support Utility) so we can have your system information:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Download the utility from the link above.
Run the exe and select 'Scan'
Save and include as an attachment in the Intel Community Forum
Ivan
I'm just following on this thread to ask you if your issue was resolved or if you need further assistance.
Ivan
