22872 Discussions
Intel HD Graphics 530 driver distorts mouse busy pointers on Windows 10 Pro 64.
GTsit
I just got a new system with i3 6100 and an ASUS B150 modo. After install windows 10 I got the problem. In order to avoid any kind of compatibility issues, I reinstalled windows and did the Microsoft Updates only and the problem reappeared. I uninstalled the driver and problem was solved. Tried beta drivers but no luck. Any suggestions?
IUman
Hello georgios.tsitouridis,
Thank you for joining the Intel communities.
Make sure you have Windows update to date with all the updates available and restart your system several times.
I also suggest getting in contact with your motherboard manufacturer in order to check for system updates, driver updates and so on.
Please try the following driver, I recommend uninstalling the old driver first, restart your system and then install the driver at the following link:
https://downloadcenter.intel.com/download/25749/Intel-Beta-Graphics-Driver-for-Windows-7-8-1-10-15-40- Download Intel® Beta Graphics Driver for Windows® 7/8.1/10* [15.40]
If that does not work try some of the suggestions provided for some customers at:
http://answers.microsoft.com/en-us/windows/forum/windows8_1-performance/right-click-on-desktop-very-slow-to-display-menu/b5c6dace-aead-4594-a75f-2f99972c50d7?page=5 http://answers.microsoft.com/en-us/windows/forum/windows8_1-performance/right-click-on-desktop-very-slow-to-display-menu/b5c6dace-aead-4594-a75f-2f99972c50d7?page=5
NOTE: This link is being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
Best wishes,
Ivan
GTsit
Thank you for your answer. I am afraid this solution do not help. I am having this issue on 2 PC both of them fully updated. Furthermore I am having some instabilities in Microsoft Edge when in Facebook where Edge is freezing up when scrolling. Again if I remove the driver the problem goes away. Especially this problem with Edge I had it some time ago with my old i5 4570s which after some update was fixed. Now I am having the i3-6100T.
IUman
If you download and install the driver from ASUS do you get the same problem?
https://www.asus.com/Motherboards/B150-PRO-GAMING-D3/HelpDesk_Download/ https://www.asus.com/Motherboards/B150-PRO-GAMING-D3/HelpDesk_Download/
Please let me know.
Ivan
GTsit
To be honest I have not tried that, I was simply using the drivers provided my windows updates and then directly from intel, though I do not think this is going to provide any different experience, not to mention that windows will try to update those drivers automatically.
IUman
I understand but I'm suggesting that to try to isolate the issue, also a customer that was able to solve this problem at the following thread:
/thread/99296 https://communities.intel.com/thread/99296
I know this is a different graphics version but it worth a try
