23758 Discussions
Intel HD Graphics Control Panel Refresh Rate - Laptop Monitor Now Pink
SDunn
Hi-
I just got a new laptop for work (Dell XPS 15) with Intel HD Graphics. I was playing around with the Intel HD Graphics Control Panel and changed the Refresh Rate from 59 Hz to 60 Hz but didn't accept the changes after hitting Apply. Now my laptop monitor's colors almost are a pinkish color; I have no idea what I did??? The only setting I changed (and didn't accept) was the change from the 59 Hz to 60 Hz.
The monitor now kind of looks like some kind of high-contrast setting...everything has this pink cast on the laptop screen, the background that was once blue is now pink.
I'm running Windows 10 if it matters.
Please help me reset this to the windows standard colors.
Thanks!
SDunn
Ok, found it after some searching, in the Color section of the control panel. Phew, that was a little scary.
SDunn
EstebanA_C_Intel
Hello, bluedunn:
I am glad to hear that you found a solution on your own for this situation.
If you require any information or support in the future, feel free to contact the Intel® Communities again.
Esteban C
2maka
I have faced similar issue, I was playing around with settings in intel HD control panel, and I changed refresh rate from 60hz to 48hz. Now screen only turns on when I connect laptop to tv via HDMI. But I can not change refresh rate when second display is connected. Is it possible to reset to defaults? Or what should I do now? I tried everything except windows 10 reinstall (I do not want that).
AlHill
This is a 4 year old thread. You should start a new thread.
Doc
Ralph00
Hi I need help...Urgent reply please.
My laptop screen suddenly turned pink while I was watching an anime(video), I went online in search of help. I have updated my display driver, scanned for virus and screen is still pink and frustrating. I have an intel celeron n3350 processor, what should I do?
AlHill
Perhaps you are experiencing a hardware failure.
Contact your laptop manufacturer for support.
Doc
n_scott_pearson
I agree with Al; this sounds like a failure in the embedded display or perhaps a loose wire going into the lid. In either case, you need to talk to the laptop vendor for repair.
Ralph00
Hi, please I need urgent reply...
I recently joined this community so I don't know to make a post. My problem is that half of my screen suddenly turned pink while I was watching an anime(video). I have updated display adapter, scan for virus but still pink and frustrating. I'm using an intel celeron n3350 processor. I never played around any settings nor has my PC ever fallen or been hit. Please HELP
