20726 Discussions
Intel HD Graphics HD on TV image too large
MS6
Hello
I have a brand new Zotac Zbox CI323, which sports a N3150 and intel hd graphics. I connect it to a somewhat older, but very good Sharp Aquos full HD TV set via HDMI cable.
On the box I am running a Windows 10 64bit pro.
My problem: the image is slightly too large, meaning at the borders it is outside the visible area of the TV.
Half of the windows start bar is invisible, and left, right and top also just about the same amount is missing.
I own also a Minix neo x5, which is a android ARM box, and when i connected it to the same tv same thing happened. Just that there in the settings I could just shrink the imaghe slightly.
On the intel box running windows I could not find such a setting. My TV unfortunatelly does not have any helpful feature for this, I scaned the menu up and down several times.
Only thing I did not try is using the advanced mode in the display driver's settings and configuring the display mode parameters manually.
I would do this, if I could find out what the current params are, so I can start there and tweak only one or two.
Or do you have another sugestion? I would greatly appreciate any help.
Hi Mishule007,
I suggest you to check with your computer manufacturer for customized graphics drivers; download and install the last version according to your OS.
https://www.zotac.com/us/files/download/by_product?p_nid=501278&driver_type=235&os=981 https://www.zotac.com/us/files/download/by_product?p_nid=501278&driver_type=235&os=981
Please keep in mind that Original Equipment Manufacturers (OEMs) can add, remove, alter or change features in the controller drivers according to their system designs.
In this hyperlink you can find Intel® HD Graphics Production Driver for Windows® 10, for your controller.
https://downloadcenter.intel.com/download/25149/Intel-HD-Graphics-Production-Driver-for-Windows-10-32-bit-N-Series-?product=81505 https://downloadcenter.intel.com/download/25149/Intel-HD-Graphics-Production-Driver-for-Windows-10-32-bit-N-Series-?product=81505
Also I try in the link below the FAQ; Why can I see the center of the Windows® desktop, but not the top, bottom, and sides?
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005502.html http://www.intel.com/content/www/us/en/support/graphics-drivers/000005502.html
Hellen.
Hi Mishule007,
I just wanted to just check-in to hear if our troubleshooting steps were fine to get a resolution.
Hellen.
