23784 Discussions
Intel HD Graphics Problem, Screen Flashes Black
I have a problem. Many times, mostly when I play a video fullscreen or a game, the screen flashes black for a second and then back to normal.
This may happen 3 or 4 times in a row. I've seen a similar discussion in the forum but i dont think it applies to my situation. This happens both with the HDMI connection and the regular. I would really appreciate your help.
System Specifications:
Operating System
Microsoft Windows 8 Pro 64-bit
CPU
Intel Core i5 3330 @ 3.00GHz
Ivy Bridge 22nm Technology
RAM
4.00 GB Dual-Channel DDR3 @ 667MHz (9-9-9-24)
Motherboard
Gigabyte Technology Co., Ltd. Z77X-D3H (Intel Core i5-3330 CPU @ 3.00GHz)
Philips FTV (1920x1080@50Hz)
Intel HD Graphics
Hard Drives
932GB Western Digital WDC WD10EVDS-63U8B0 (SATA)
298GB Western Digital WDC WD3200KS-00PFB0 (SATA)
Optical Drives
TSSTcorp CDDVDW SH-224BB
Audio
Intel Display Audio
Monitor
Name Philips FTV on Intel HD Graphics
Current Resolution 1920x1080 pixels
Work Resolution 1920x1040 pixels
State enabled, primary, output devices support
Monitor Width 1920
Monitor Height 1080
Monitor BPP 32 bits per pixel
Monitor Frequency 50 Hz
Device \\.\DISPLAY1\Monitor0
Intel(R) HD Graphics
Memory 1803 MB
Memory type 2
Driver version 9.17.10.2875
OpenGL
Version 4.0.0 - Build 9.17.10.2875
Vendor Intel
Renderer Intel HD Graphics 2500
GLU Version 1.2.2.0 Microsoft Corporation
NICHOLAS_F_Intel
Hi George,
Can you tell me the current version of your motherboards BIOS?
-Nic
I am not sure this is the thing you want, but in the msinfo32 file it says:
BIOS Version/Date American Megatrends Inc. F8, 11-May-2012 and
SMBIOS Version 2.7
NICHOLAS_F_Intel
Thanks for the info George,
The BIOS version you currently have (F8) has seen a few updated/corrections. Gigabyte is currently on F16. I've provided a link to the download page for your motherboard here; http://www.gigabyte.us/products/product-page.aspx?pid=4144# bios http://www.gigabyte.us/products/product-page.aspx?pid=4144# bios
Download the latest BIOS update and run it, and let me know if you're issue is corrected or not.
-Nic
I tried to run it and it gives me a message that it is not supported for the 64bit version of Windows 8 which i have.
Is there a compatible version for my Windows somewhere?
Thank you.
NICHOLAS_F_Intel
It would appear that the Gigabyte BIOS do not have an executable updater. I checked the specs for your motherboard, and it does support "Q Flash" - which can be used for updating ("flashing") your BIOS. Here is a guide from Gigabyte on how to do so; http://www.gigabyte.com/MicroSite/121/flashbios_qflash.pdf http://www.gigabyte.com/MicroSite/121/flashbios_qflash.pdf
Give that a try, and let me know how it goes!
-Nic
Thank you very much. I followed the steps and the BIOS was updated to F16.
Lets hope now that the black flashes will stop!
Thank you!
