23784 Discussions
Intel HD Graphics Problems.
Starting today I have noticed that my video games have started to drop in frames by a ton. Earlier today I got an update for my graphics on my Intel Core i3 and when I started up League of Legends my framerate would drop to the low 20s and go lower when I got into fights. Before I would get a constant 30 frames because thats what I capped it at. I tried system restore but it made it worse. I also tried Counter Strike Source and played about 5 mins to notice that when I turn the flashlight off and on it would lower to about 10 frames when the flash light is on and it would go back to its regular framerate once I turned it off.
What could be wrong with my computer? How should I go about fixing this?
and were you able to play on widescreen? i've managed to make diablo 2 work with a pach from blizzard, but still no widescreen. i think this is due to intel hd graphics card. has anyoane have a clue?
I just got done playing League of Legends and noticed that I cant only play in windowed mode and I only get 20+ frames out of fights and 15 in fights
Hi there!
Did you check the list of tested games for your graphics controller?
This is available at http://www.intel.com/support/graphics/sb/CS-031017.htm http://www.intel.com/support/graphics/sb/CS-031017.htm
If you do not find your game, Intel offers a troubleshooting guide, this may help fixing your issue
http://www.intel.com/support/graphics/sb/cs-010486.htm http://www.intel.com/support/graphics/sb/cs-010486.htm
Allan.
