23784 Discussions
Intel HD Graphics doesn't show version
WKou
For some reason, my Intel HD Graphics adapter doesn't show it's version. Help?
Stefan3D
When you say "version" you mean a three- or four-digit number seen with other GPUs?
A couple of Intel GPUs have no number in description.
Click details/hardware Ids where you see a hex number DEV_XXXX
Look-up the architecture in this list: https://github.com/GameTechDev/gpudetect/blob/master/IntelGfx.cfg gpudetect/IntelGfx.cfg at master · GameTechDev
WKou
My hex code is DEV_0F31 but it isn't listed in the IntelGfx.cfg for some reason
DNorf
W menadżerze urządzeń tego nie sprawdzisz. Żeby sprawdzić model swojej karty graficznej musisz wejść w panel sterowniczy grafiki HD- opcja centrum informacji
WKou
Uhh...Nope.
Stefan3D
So the list above is incomplete (although it's from an Intel dev).
Next step: search your device ID at http://www.catalog.update.microsoft.com/Search.aspx?q=%20pci%5Cven_8086%26dev_0f31%26subsys_161d1043 Microsoft Update Catalog
Look into the INF where it reveals 0F31 = Valleyview
WKou
no no like I need the graphic card version
I'm getting a game and it says minimum hardware contains video card at least Intel HD Graphics 4100
So I'm just trying to see if my computer can run it or not
my cpu and other stuff is fine
DNorf
Jest to Intel HD Graphics bez żadnego numerka (inaczej zwana GMA 5700MHD)... czyli pierwsza generacja słabego intela:)
I would like to have additional information about your system configuration. Please run the following utility and attach the results.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Intel® System Support Utility
In order to attach files, make sure you select the "Advanced Editor" option in the top right of your reply window. You will then be presented with an attach file dialogue at the bottom of the reply.
Allan.
WKou
I don't think this is helpful though...it still says Intel HD Graphics
Thanks for the report, this is helpful to check your hardware and software configuration.
The integrated graphics on the Intel® Pentium® Processor N3540 is Intel® HD graphics (Baytrail) this is similar to an Intel® HD graphics 4000.
The latest graphics drivers available for your graphics controller would be version https://downloadcenter.intel.com/download/25977/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-33-?product=81499 4425
Please do let me know if you need further assistance with your Intel product, I will be glad to assist you.
Allan.
