23741 Discussions
Intel HD Graphics installation Problem
I have setup a new system & the configurations as follows.
Intel Core i3 540 @ 3.06Ghz
DH55PJ Board (With H55 Express chipset)
Ram 2GB (DDR3)
Windows 7 Professional 32 bit
This is not a branded system & I have assembled it my own. I need to use Integrated HD graphics, but the drivers came with bundle is not supporting. After I install drivers & once it re-start, system can't boo up to windows & it is re-starting again & again. I can log on through safe mode only to uninstall drivers. Pls help me on this as I have try out varies drives on the net & I have try out "have disk" method also, but no success yet & running with standard AGP adapter.
Thanks in advance.
Sathika.
Actually the problem was with C-State & C2-State in Bios power options. please disable both if anybody is having this problem with you. it will solve the problem.
Good Luck.
