23771 Discussions
Intel HD graphics 4000
CMyer2
Ok so I run the driver update utility and it says there is a new update. So I click on update and it says the file name is changed, moved or removed. So I search manually for it. I'm running Windows 8.1 64 bit. My version is currently 10.18.10.3345 When I try to download I keep getting a message that says the driver being installed is not validated find appropriate driver, or something along those lines. So, um, what am I doing wrong?
Jose_H_Intel1
Hi Lf11monkey, this is the latest driver for Intel® HD Graphics 4000: https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=23885 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=23885
If the issue persists, you may try the alternate installation method provided below or uninstalling the older version first. Please remember that some systems require the specific drivers provided by the http://www.intel.com/support/oems.htm system manufacturer, so you can get them from their website.
http://www.intel.com/support/graphics/sb/CS-033916.htm Desktop graphics drivers — How to Manually Install a Driver in Microsoft Windows 8* or Windows 8.1*
