23777 Discussions
Intel HD3000 Vsync problem
Hello.
I have a laptop with and Intel HD3000 gfx.
I have problem with games that don´t have option under settings to disable Vsync.
I have disbaled it in the gfx driver software but i still only gets max 60fps.
I have the newest driver ver. but still the same problem.
I have searched alot for a answear for this but i only find people with the same problem.
Anyone that knows a fix for this problem?
Regards.
Martin
Allan_J_Intel1
Hi there!
If you need to disable vsync, it has to be through your game settings because the Intel driver does not offer an option to disable vertical sync within graphics control panel.
I recommend contacting your computer manufacturer and try to get a customized driver for your computer model.
Allan
MSchm21
Valued Contributor I
Is it difficult to implement a working on/off Vsync option through the driver? Is it planned?
Like i said its hard to use vsync settings if there is no option for this in the game.
And there is a option under 3D settings in the driver software to turn vsynd off.
Why does this crappy driver software have this setting if its not supported?
And why should me latptop manufacturers build a working driver for your "product/chipset" <- Not logical.
Regards martin
rofl, they have your money they dont care...
their new motto should be " buy our Intel HD and we will screw you"
Now if you bought AMD you can play any game out there as they are supported...
