20795 Discussions
Intel HD4000 Bad Opengl support and missing extension.
CEstr
Hello One thing is that many entries currently no support in current drivers testing by 10.18.10.3496 with Windows 8.1 x64
no idea if this issue Windows only related.
TODO LIST :
Opengl 3.0
Missing and unsupported
--glBeginConditionalRender
-glBeginTransformFeedback
-glBindBufferBase
-glBindBufferRange
-glBindFragDataLocation
-glClampColor
-glClearBuffer*
-glColorMaski
-glDisablei
-glEnablei
-glEndConditionalRender
-glEndTransformFeedback
-glGetBoleani_v
-glGetFragDataLocation
-glGetIntegeri_v
-glGetStringi
-glGetTexParameter*
-glGetTransformFeedbackVarying
-glGetUniformuiv
-glGetVertexAttribli*
-gllsEnabledi
-glTexParameter*
-glTransformFeedbackVaryings
-glUniform*
-glVertexAttrib*
For Opengl 3.1
missing and not supported
-gldrawArrayInstanced
-glDrawElementsInstanced
-glTexBuffer
-glPrimitiveRestarIndex
For Opengl 3.2
Missing and not supported
- glGetInteger64i_v
- glGetBufferParameteri64v
- glProgramparameteri
- glFramebufferTexture
- glFramebufferTextureFace
For Opengl 3.3
- glVertexAttribDivisor
For Opengl 4.0
missing and unsupported
-glBlend*
-glMinSampleShading
For Opengl 4.1
- Shading language 4.1 ¿Limited by Intel?
For Opengl 4.2
- Shading language 4.2 ¿limited by Intel?
but missing and unsupported
- GL_ARB_Shader_image_load_store
For Opengl 4.3
-Shading language 4.3 ¿limited by Intel?
but missing and unsupported..
-GL_ARB_clear_buffer_object
-GL_ARB_compute_shader
-GL_ARB_copy_image
-GL_ARB_debug_group
-GL_ARB_debug_label
-GL_ARB_debug_output2
-GL_ARB_ES3_compatibility
-GL_ARB_explicit_uniform_location
-GL_ARB_invalidate_subdata
-GL_ARB_shader_storage_buffer_object
For Opengl 4.4 Only supported GL_ARB_Buffer_storage
The main problem some aplication used some extensions required . Why do not these extensions are supported? maybe Intel update drivers fix in the future Thanks
Allan_J_Intel1
Thanks for joining the community and for pointing out the error.
I am sorry to hear that have had issues with the Intel® Graphics Controller on your computer.
I would need more information in regards to your system configuration:
Please copy-paste or attach the Graphics report generated within the Intel(R) Graphics User Interface. To access this report, please click on Start >> Control Panel >>Intel GMA driver >> information >> Save To File...
http://www.intel.com/support/graphics/sb/cs-009476.htm http://www.intel.com/support/graphics/sb/cs-009476.htm
Also, please include DirectX report, click Start, and click Run, type dxdiag in the Open box, and then click OK.
Allan.
CEstr
It's here attached If you needed other information tell me thanks you
Allan_J_Intel1
Thank you for the information.
I am currently researching on this issue. As soon as I can, I will send you a message with my findings. Thank you for your patience and understanding.
Allan.
CEstr
For more information I used GLview for view GL extension supported.
http://www.realtech-vr.com/glview/download.php OpenGL Extensions Viewer - Download
You can view extension supported and missing
Attached Extension verification:
CEstr
Update first post
Intel beta drivers Build (10.18.10.3496) are supported new extensions Opengl .
-GL_ARB_framebuffer_no_attachments
-GL_ARB_stencil-texturing
- GL_ARB_buffer_storage
-GL_ARB_texture_storage_multisample
-GL_EXT_shader_integer_mix
ROBERT_U_Intel
@Carlos26, I was going to ask if you actually had the 3496 driver installed correct5ly in your first post. I appears you do now. The 3496 does support all extensions.
Robert
CEstr
@Robert_U Thanks for you response yes, I've installed this version 3496. and not resolved to all.
I.E : Extension GL_ARB_Shader_image_load_store not supported on Ivy bridge but supported Haswell devices ????
Also I Tested on https://github.com/DHrpcs3/rpcs3/ DHrpcs3/rpcs3 · GitHub this App Requires fully OpenGL3.3 support but don't work glEnable error x0500 and also Opengl Initialization glDepthBoundsEXT failed on Intel HD graphics but working on AMD/NVIDIA GPU
ROBERT_U_Intel
Hi Carlos
We have had several OGL fixes since the 3496 driver you original tested on. Could you test with the latest version 3945 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24329&lang=eng&ProdId=3711 Intel® Download Center and provide your feedback on remaining issues?
Robert
ROBERT_U_Intel
Carlos,
This is correct, we support GL_ARB_Shader_image_load_store (which is an OGL 4.2 feature) on Haswell, but not on Ivybridge (IVB= OGL 4.0).
As for glDepthBoundsEXT, its part of the GL_EXT_depth_bounds_test extension, which we do not support on any configuration currently.
Thanks Robert
