23820 Discussions
Intel HD4000 Driver problem
dyiu
I use HP 8300 i7-3770 8G with windows 7_64, Virutal Machine + Genymotion are used to play the android games on the PC.
If I install the lastest version 4425 HD4000 driver from Hp or Intel, the screen graphic is flashed and cannot show the true picture when I play a game called "Little Empire" and jump to "training page" from main page.
If I install old verison 2639 HD4000 driver from "Intel_GFX_Win7_64_8.15.10.2639_PV.exe", the screen graphic at the training page is ok without any problems, but the andrioid simulator on virutal machine will hang after running for 10-30 minutes.
What is the difference between HD4000 driver 2639 version and 4425 version ? How to solve ? Please advice !
Stefan3D
Here is a list of all available drivers: https://downloadcenter.intel.com/product/81499/Intel-HD-Graphics-4000 Downloads for Intel® HD Graphics 4000
You can try to find the happy medium which works with both programs, lot of work though without achievement guarantee.
dyiu
I tried the several versions(e.g. 2867, 3040, 3090, 4061, 4229, 4425) Intel HD 4000 Drivers for Windows 7_64, only version 2639 works, all others have the same problem.
I tested the android game with 2 computers:
1) Dell Optiplex 7010 i7-3770 16G windows 7_64, onboard HD4000,
2) HP Elite 8300 i7-3770 16G windows 7_64 onboard HD4000.
I found that only version 2639 HD4000 driver could show the true screen at some game pages for both computers, but Dell will not hang and work ok. HP will hang the game screen while working for a moment. I also test different android simulators, all got the same problem.
So I would like to know what is version 2639 HD4000 driver difference from others !!
Hello deville,
In this case, the driver is meant to run on a specific OS (Windows 7* in this case), since you are trying to emulate a different OS in which the graphics driver is not supported, you may experience some issues.
Regarding your question about the difference between graphics versions, you can refer to the release notes of each specific driver, they can be found in the link provided by Stefan3D.
I hope this helps.
Juan V.
Hello deville,
I was reviewing this thread and I wanted to know if you need further assistance?
Juan V.
dyiu
About the difference between graphics versions, I could not find the release notes of each specific driver, would you provide the direct link.
Problems are not solved yet
Hi deville,
To get the release notes for each driver (Intel® HD Graphics 4000) please follow the next steps:
The same applies to all download available https://downloadcenter.intel.com/product/81499/Intel-HD-Graphics-4000 here.
Remember that since you are trying to emulate a different OS in which the graphics driver is not supported, you may experience some issues.
Juan V.
dyiu
Thanks for your tutor, but I could not find the HD4000 version 2639 windows_7_64bits driver at the download website ??
Hi deville,
If a specific version is not available most likely, it is an OEM version of the driver. The website lists all the existing versions for the Intel® HD Graphics 4000.
Juan V.
Hello deville,
Juan V.
Hello deville,
Juan V.
