23764 Discussions
Intel HD4000 driver bug
RGroo6
Hi
these bugs are caused by Intel drivers in Autodesk Maya, these bugs do not occur when using default windows drivers.
When i am trying to select edges or faces the framerate will drop to 0 for a small amount of time making it impossible to work with, this however does not happen when i try to select vertices.
DArce
Valued Contributor III
Please post the version of the Autodesk software you are using, full steps to reproduce the issue and the name of the software used to check the FPS.
In addition, post the dxdiag report from the system you are having issues with
