23802 Discussions
Intel HD510 + H110 chipset drivers problem
Hello, found some proiblem with intel drivers for Intel HD Graphics
My system configuration is:
Mainboard: Asus H110M-PLUS D3
CPU - Intel Pentium G4400
System: Windows 10 64 bit
After installing Intel drivers to the system - I have a troubles with fonts and all picture, everything looks bad, fonts not clear.
I tried to change a diffirent refresh rate ant type of polarisation. Resolution is native for display - 1920x1080.
But nothing helps me.
With Intel driver:
With Microsoft driver (no Intel driver in the system)
Hello Yuldabayev,
Have you tried using a different driver version? Try this version https://downloadcenter.intel.com/download/26404/Intel-Graphics-Driver-15-45-?product=88351 Download Intel® Graphics Driver [15.45], and use his method to ensure the installation http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html Manually Install an Intel® Graphics Driver in Windows® 10 and Windows....
Amy.
Dear Amy,
I tried all versions of drivers since dec2015 till now, include latest.
The problem is not fixed.
/thread/108550 Yuldabayev,
Let me gather more information in regard to your system, please use the following tool https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility to get that information, once done attach it. To attach a file, you must click "Use Advanced Editor" in the top right corner of the response box, then the "attach" option will appear in the bottom right corner of the response box. One more question, you mentioned that the issue started after installing our drivers, do you remember that version you had installed when your system was working OK?
Amy.
Were you able to get that file? This will help to gather some details from your system in order to find a best way to address this matter.
Amy.
Hello, Amy,
I tried to fix this issue for a couple days more. I installed other versions of Windows 10 (32 bit, Home and Prof) but I have no results.
Finally I installed a dedicated video card (Nvidia GT730 witn Nvidia drivers) and all my troubles was solved.
Yevgeniy
/thread/108550 Yuldabayev, I am glad to hear that!
My apologies for any inconvenience, and if you need further assistance let us know.
Amy.
