Annonces
23459 Discussions
Intel Iris Graphics Driver Installation Error
ABenn5
Débutant
5 577 Visites
So I am attempting to install the Intel Iris Graphics Driver for Windows 7/8/8.1 64bit version to fix graphical errors within a game(Titanfall).
Everytime I try to install the drivers I get an error.
If I try to install the driver from the exe file here http://https//downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24348 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24348 I get an error saying that This computer does not meet the minimum requirements for installing the software.
If I try to install it via the zip file:
Control Panel>Device Manager>Display Adapters>Update Driver Software>Browse My Computer>Let Me Pick>Have Disk>Browse>kit64ics.inf>Select Intel Iris Graphics 5100(or pro 5200)
I get the error saying The Driver Selected for your device does not support this version of windows.
System stats:
Operating System: Windows 8.1 64-bit (6.3, Build 9600) (9600.winblue_r3.140827-1500)
Language: English (Regional Setting: English)
System Manufacturer: TOSHIBA
System Model: Satellite S55-A
BIOS: 1.70
Processor: Intel(R) Core(TM) i7-3630QM CPU @ 2.40GHz (8 CPUs), ~2.4GHz
Memory: 8192MB RAM
Available OS Memory: 8068MB RAM
Page File: 4555MB used, 11512MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 11
Form of Computer: Laptop(if you couldn't tell by model)
0 Compliments
8 Réponses
Allan_J_Intel1
Employé
4 485 Visites
Thanks for joining the Graphics community.
I just verified installation with have disk method, here are the steps I used:
1. Login with administrator privileges
2. Open Control Panel
3. Open Device Manager
4. Click on "Display adapters"
5. Double click "Intel HD Graphics"
6. Click on the "Driver" tab
7. Click on "Update Driver" button
8. Click on "Browse my computer for driver software"
9. Click on "Let me pick from a list of device drivers on my computer"
10. Click on "Have Disk" button
11. Click "Browse"
12. Navigate to the folder that you unzipped the Beta Intel HD Graphics driver to
13.Navigate to the Graphics sub-folder
14. Double click the igdlh64.inf
15.Click "OK"
16. Click "Next"
Driver should now be installing.
17. If successful, click "Close"
Reboot.
Allan.
ABenn5
Débutant
4 486 Visites
Hey Allan, Thanks for the response. I followed the steps you gave me but I run into an issue when I get to step 14.
I am in the graphics subfolder yet there is no igdlh64.inf file located there, there is only a kit64ics.inf there. I also tried to go directly to the subfolder with just the file explorer and again there is no igdlh64.inf file.
Is there some reason that this file does not exist when I download it? As I have downloaded it through your link and the original link that I had posted in the question.
0 Compliments
Allan_J_Intel1
Employé
4 486 Visites
The driver does not seem to be there because, I have provided you with wrong driver version, and I apologize.
According to your system specifications, the processor model Intel(R) Core(TM) i7-3630QM CPU integrates Intel® HD Graphics 4000 and the driver is not the same for Intel® HD Graphics 5100 or 5200 series.
Please try this link: https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24329&lang=eng&ProdId=3712 Intel® Download Center
Allan.
0 Compliments
ABenn5
Débutant
4 486 Visites
Thanks Allan, I did my digging myself and I realized that I have a 3rd gen i7 and iris 5100 and 5200 are for 4th gen. Before you responded the first time I did manage to fix the graphical errors myself using the 3rd party application slimdrivers, but after seeing your post I figured I should try the intel recommended driver.
I installed the driver via the link you gave me and it didn't have the graphical errors and I was having higher fps than with the driver I installed from the slimdrivers app.
Thanks for all the help!
0 Compliments
Allan_J_Intel1
Employé
4 486 Visites
Thanks for sharing your results. I am glad your computer is working now.
Allan.
0 Compliments
aalon8
Débutant
4 485 Visites
i have the same problem with the driver i have 4th gen 4400 hd intel what i do? it says is not compatible with this windows version i have 8.1
0 Compliments
aalon8
Débutant
4 486 Visites
0 Compliments
aalon8
Débutant
4 486 Visites
0 Compliments
Répondre
