23812 Discussions
Intel Iris Xe graphics
Ayalandia
Hola, compre una placa de video Itel Iris Xe graphics, "Intel(R) Iris(R) Xe Graphics" y cuando intento instalar los drivers me queda la pantalla congelada y en negro. A alguien le sucede lo mismo?, tiene alguna solución?
Mi PC: Motherboard= ASUS PRIME H510M-E
            CPU= Intel Core i5 10-400F
            GPU= Intel(R) Iris(R) Xe Graphics 4gb
Jean_Intel
Hello Ayalandia,
Our support is only provided in English. We may not be able to translate the screenshots attached to the thread. To better assist you, we use a translation tool, hence; the translation may not be completely accurate.
The Intel® Iris® discrete graphics card comes included in specific OEM systems but isn't available for purchase as a stand-alone card. The Iris Xe discrete add-in card is a focused product developed with two partners who worked with Intel to focus on delivering more compelling options for system integrators.
Jean O.
Ayalandia
Hi, sorry my english is not well, Ok so what driver do I need for this GPU
Thank you very much ❤️
Jean_Intel
Hello Ayalandia,
Thanks for your response.
I suggest contacting your motherboard manufacturer to check if the device is compatible with your system. Remember that this Intel® Iris® Xe is not sold at retail. It comes in specific (original equipment manufacturers) OEM systems and may not be compatible with your motherboard BIOS.
Jean O.
Ayalandia
Yes, I already asked it is only compatible with H510M-E which is my motherboard, B460 and B560 only with those motherboards is it compatible
