23769 Discussions
Intel Quick Sync on Windows Server 2012
SMisk
Hello everybody,
I have an issue with Windows Server 2012 and Intel Quick Sync technology. It's simply not working on Windows Server 2012. I got some glues that there is an option to enable it editing Setup.if2 file but don't know what to edit.
Is there any resolution or Intel Quick Sync is not supposted to work on Windows Server 2012?
CPU is :
Intel i7 4770 3.4GHz
DArce
Valued Contributor III
This feature is enabled when using the video driver for the video controller. Now, the drivers we provide for the Intel® HD Graphics 4600 are validated for desktop edition operating systems. Hence this might be compatibility issues with the operating system that is being used.
SMisk
Thank you for your reply. So that means Quick Sync is not supported on Windows Server 2012?
DArce
A compatible operating system/driver combination needs to be used for this to work.
