23767 Discussions
Intel(R) 945 Express Chipset Family
I have the above mentioned chipset and am looking to discover whether it is UHCI compliant. I have a DAC that runs through a USB a driver that requires this compliance. Other information I have from the Driver ID utility is the following
Detected Chipset:
http://support.intel.com/support/chipsets/sb/CS-020683.htm Intel(R) 945 Express Chipset Family
Chipset Components
Memory Controller:
82945G/GZ
I/O Controller:
Intel(R) 82801GB/GR I/O controller hub (ICH7/ICH7R) SATA Controller found in IDE mode
I am frustrated and looking to see if I can install this driver but is dependent on UHCI compliance.
Help!
DArce
Valued Contributor III
It supports Universal Host Controller Interface (UHCI), Revision 1.1. For more information on this, please check the Intel (R) ICH 7 datasheet at:
http://www.intel.com/content/dam/doc/datasheet/i-o-controller-hub-7-datasheet.pdf http://www.intel.com/content/dam/doc/datasheet/i-o-controller-hub-7-datasheet.pdf
