23832 Discussions
Intel(R) Celeron(R) CPU 1005M @ 1.90GHz 1.90 GHz...... Application has been blocked by graphics hardware fix please!!
JJuvi
So recently I have gotten Fallout 4 for Pc. I am running on Windows 10, and have been trying to fix the error of "Application has been blocked by Graphics hardware" for quite a long time now. I do not know what else kind of Info I am supposed to give you, but everything on my computer is updated, and I am trying to find a workaround for this. Please help, I am about to go insane on this computer..
Hello JuviaLocksera:
On the following link you will be able to find the latest version of the graphics driver for Intel® HD Graphics controller, please un-install the current driver on your PC, and then try to install the driver manually:
Driver 4425:
https://downloadcenter.intel.com/download/25977/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-33-?product=81501 https://downloadcenter.intel.com/download/25977/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-33-?product=81501
Instructions to install the driver manually:
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html
In order to better assist you we just need to verify a few details:
What is the model of the board?
If this is a laptop, what is the model of the laptop?
Did Fallout 4 work fine before?
Did you try a BIOS update on the PC?
Please let me know the results of trying the driver above.
Alberto
JJuvi
The Update did not work. I am not really good with this kid of thing, so I dont know giw to find my model of the board..
Fallout 4 did work fine before, but a few day after I kept getting this error.
Thank you very much for that information.
The thing is that for us to be able to assist you, we need that information.
Maybe you can see a number on the laptop, or a model on it?
Alberto
JJuvi
My computer is a Satellite C55t-A5222
Serial number is 6D210099Q
This is all I know.
Since the driver version 4425, did not worked, we can try to install the driver provided by Toshiba, look for the option that says "drivers and updates" and then select display on the options to the left:
http://support.toshiba.com/support/modelHome?freeText=1200005866 http://support.toshiba.com/support/modelHome?freeText=1200005866
The laptop supports Windows® 8, is that the operating system on the laptop?
When you said the driver update did not worked, you mean it got installed but the problem persists, or the driver did not got installed?
Alberto
I just wanted to check if you were able to install the driver from Toshiba, and also I wanted to verify if the problem persists or if it was resolved.
Alberto
