23837 Discussions
Intel(R) Graphics Media Accelerator 3600 Series WINDOWS XP driver
I am using Acer Aspire One D270. Downgrade from Windows 7 to XP. It hard finding the XP driver. Only Wireless driver is working but the LAN(installed but there some yellow icon in device manager), and VGA(installed but there some yellow icon in device manager) and PCI device still having problem to find.
Fred_D_Intel
Hi all,
What happens is that Intel has no plans to develop graphics driver for other operating systems. The operating system that is compatible with Intel GMA 3600 is Windows 7 32-bit. For more information you can check this link http://www.intel.com/support/graphics/intelgma3600/sb/CS-033597.htm http://www.intel.com/support/graphics/intelgma3600/sb/CS-033597.htm
Fred_Intel wrote:
Hi all,
It does not work as they should:
Make a normal driver. It does not matter what operating system, but working with the normal performance of 2D (at least)!
WSule1
I've got an Acer Aspire One D270-1492. I was almost suicidal after trying everything here but nothing worked. This finally worked for me.
1) Go to the following link.
http://www.4shared.com/zip/JIZnHKCV/Intel_Graphics_Media_Accelerat.html http://www.4shared.com/zip/JIZnHKCV/Intel_Graphics_Media_Accelerat.html
If you don't have an account there, you must register, but it's free.
2) After you get set up you can download the file, in zip form. Unzip it.
3) Next, go to your device manager and the 3600 accelerator with the yellow icon (if there's no yellow icon skip this step). Right click it and uninstall whatever may be in there.
4) Restart machine.
5) Go to the Device Manager again and right click the IGMA 3600 icon again. Click Update driver.
6) In the wizard, select the Install From Specific Location option.
7) NEXT window, select Don't Search, I Will Choose the Driver to Install.
😎 NEXT window, select Have Disk (you don't need one).
9) Now, in the Install From Disk window, BROWSE to the location of the downloaded file and open the file.
10) Open the resulting file, and here it is . . . . . click on the "iegd" icon and open it. Windows should begin installing it.
