23804 Discussions
Intel(R) HD Graphics 3000 HDMI not detected
Hey
I've have an Inter core(tm) i5-2500 CPU @ 3.30Ghz motherboard with 64 bit os.
I used to be able to view on the hdmi cable and i restarted my pc today and the HDMI cable is now no longer detected. My TV picks up that there is a device plugged into the HDMI but the computer doesn't. I installed the latest drivers and still nothing.
Help
Ben
DArce
Valued Contributor III
Could you please attach the graphics report generated by the Intel® Graphics and Media control panel?
For information on how to get the report, please check this article:
http://www.intel.com/support/graphics/sb/cs-009476.htm http://www.intel.com/support/graphics/sb/cs-009476.htm
In addition, please let us know if any hardware or software change has been done recently and what if the model and manufacturer of the computer or motherboard you are using.
I am not the original poster, but I am having the same problem. Here is my control panel report:
Report Date: 12/25/2012
Report Time[hh:mm:ss]: 14:38:09
Driver Version: 9.17.10.2875
Operating System: Windows 7 Service Pack 1(6.1.7601)
Default Language: English (United States)
DirectX* Version: 11.0
Physical Memory: 6058 MB
Minimum Graphics Memory: 64 MB
Maximum Graphics Memory: 1696 MB
Graphics Memory in Use: 94 MB
Processor: Intel64 Family 6 Model 42 Stepping 7
Processor Speed: 2394 MHz
Vendor ID: 8086
Device ID: 0116
Device Revision: 09
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 3000
Video BIOS: 2108.5
Current Graphics Mode: 1366 by 768
* Devices Connected to the Graphics Accelerator *
Active Notebook Displays: 1
* Built-in Display *
Monitor Name: Generic PnP Monitor
Display Type: Digital
Gamma Value: 2.2
DDC2 Protocol: Supported
Maximum Image Size:
Horizontal: 13.39 inches
Vertical: 07.48 inches
Monitor Supported Modes:
1366 by 768 (60 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Not Supported
Raw EDID:
00 FF FF FF FF FF FF 00 30 E4 DC 02 00 00 00 00
00 14 01 03 80 22 13 78 0A 09 15 9D 5F 59 9B 27
19 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 58 1B 56 7E 50 00 0E 30 24 30
35 00 58 C2 10 00 00 19 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 FE 00 4C
47 20 44 69 73 70 6C 61 79 0A 20 20 00 00 00 FE
00 4C 50 31 35 36 57 48 34 2D 54 4C 41 31 00 09
* Other names and brands are the property of their respective owners. *
The new driver does not solve the issue for me.
I am also experiencing the same problem, and the new driver does not solve the problem for me too.
DArce
Could you please provide us the dixdiag in your system? To get this report please go to the Start menu, type dxdiag and press enter then go to Save All Information. Copy the contents on the saved file and paste it
System Information
Time of this report: 1/31/2013, 21:16:41
Machine name: METAMOQ
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120830-0333)
Language: English (Regional Setting: English)
System Manufacturer: LENOVO
System Model: 1066AJU
BIOS: Default System BIOS
Processor: Intel(R) Core(TM) i5-2430M CPU @ 2.40GHz (4 CPUs), ~2.4GHz
Memory: 6144MB RAM
Available OS Memory: 6058MB RAM
Page File: 3354MB used, 8760MB available
Windows Dir: C:\windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 3000
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0116&SUBSYS_397517AA&REV_09
Display Memory: 1696 MB
Dedicated Memory: 64 MB
Shared Memory: 1632 MB
Current Mode: 1366 x 768 (32 bit) (60Hz)
Monitor Model: unknown
Monitor Id: LGD02DC
Native Mode: 1366 x 768(p) (59.996Hz)
Output Type: Internal
Driver Name: igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumd32,igd10umd32,igd10umd32
Driver File Version: 9.17.0010.2932 (English)
Driver Version: 9.17.10.2932
DDI Version: 10.1
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 12/12/2012 16:42:36, 12615680 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4256-11CF-6E7F-7F19B7C2C435}
Vendor ID: 0x8086
Device ID: 0x0116
SubSys ID: 0x397517AA
Revision ID: 0x0009
Driver Strong Name: oem19.inf:Intel.Mfg.NTamd64:iSNBM0:9.17.10.2932:pci\ven_8086&dev_0116
Rank Of Driver: 00E02001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,YUY2) Fram...
Hi Diego
Here are the information after running 64-bit dxdiag:
System Information
Time of this report: 2/1/2013, 12:16:44
Machine name: SAMUELTAI-PC
System Manufacturer: SAMSUNG ELECTRONICS CO., LTD.
System Model: RF511/RF411/RF711
BIOS: AMIBIOS Version 10HX.M034.20110426.SSH
Processor: Intel(R) Core(TM) i7-2630QM CPU @ 2.00GHz (8 CPUs), ~2.0GHz
Memory: 8192MB RAM
Available OS Memory: 8104MB RAM
Page File: 2657MB used, 13547MB available
DxDiag Version: 6.01.7601.17514 64bit Unicode
DxDiag Notes
Display Devices
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0116&SUBSYS_C0A5144D&REV_09
Monitor Id: SEC3549
Native Mode: 1366 x 768(p) (60.225Hz)
DDI Version: 10.1
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4256-11CF-897C-AFE0B7C2C435}
Vendor ID: 0x8086
Device ID: 0x0116
SubSys ID: 0xC0A5144D
Revision ID: 0x0009
Driver Strong Name: oem115.inf:Intel.Mfg.NTamd64:iSNBM0:9.17.10.2932:pci\ven_8086&dev_0116
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) ...
DArce
Stephan, could you please let me have the full model of the Lenovo system that you have?
Samuel, I believe that your system uses switchable graphics as I can see Intel® and Nvidia drivers listed in your dxdiag report and also in Samsung's web site. Please keep in mind that such systems using switchable graphics require a special driver that is only customized and provided by your computer manufacturer. In this case you should check with Samsung on this.
Could you please specify what video drivers are being used? Also provide the model of the motherboard or laptop that you are using and if you have tested the drivers from the motherboard or laptop manufacturer? (If so, please also list those versions)
What happens if you try using another web browser such as IE or Firefox?
It is a Lenovo V570, probably manufactured some time in mid-late 2011.
DArce
Stephan,
What happens if you try the video driver provided by Lenovo posted here?
http://support.lenovo.com/en_US/downloads/default.page?selector=expand http://support.lenovo.com/en_US/downloads/default.page?selector=expand
As a matter of fact I also see a nVidia* driver posted there, which may be a sign that your system also feature switchable graphics.
Yes, I have tried Lenovo's driver. This particular laptop does not have switchable graphics.
DArce
Thank you Stephan,
I just wanted to inform you that we are investigating on this issue. We appreciate your patience on this matter.
I am experiencing the exact same problem in an ASUS Zenbook UX31E. I have just upgraded to the latest Intel drivers available and the problem with the HDMI persists.
In my case, and just as other people mentioned, if I plug the microHDMI and then install the drivers it start working... but just until I unplug the cable or reboot the system.
After checking this forum it seems that this is a wide known issue that has been going on for months now (actually that's why I did not create a new thread). So hopefully Intel will be able so solve it shortly now... I am willing to provide feedback or more information from my case if needed.
Hi there i also have a similar problem, i formatted my Laptop and installed the latest driver and now not my PC or my Laptop are recognizing one another when connected with HDMI
here is my DXDIAG report:
System Information
Time of this report: 3/10/2013, 12:33:50
Machine name: KPNBDEAN
Operating System: Windows 7 Enterprise 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130104-1431)
System Manufacturer: Dell Inc.
System Model: Dell System Vostro 3750
Processor: Intel(R) Core(TM) i7-2670QM CPU @ 2.20GHz (8 CPUs), ~2.2GHz
Memory: 8192MB RAM
Available OS Memory: 8086MB RAM
Page File: 3816MB used, 12354MB available
Windows Dir: C:\Windows
DxDiag Notes
Display Devices
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0116&SUBSYS_04C61028&REV_09
Current Mode: 1600 x 900 (32 bit) (60Hz)
Monitor Id: LGD0303
Native Mode: 1600 x 900(p) (60.080Hz)
DDI Version: 10.1
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4256-11CF-EC78-CC24B7C2C435}
Vendor ID: 0x8086
Device ID: 0x0116
SubSys ID: 0x04C61028
Revision ID: 0x0009
Driver Strong Name: oem45.inf:Intel.Mfg.NTamd64:iSNBM0:9.17.10.2932:pci\ven_8086&dev_0116
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2)...
agros2
Hi, I have the same problem. I have a Lenovo v570 with Intel HD 3000 graphics and there is no way to connect my laptop to a LG Led tv... I've been trying a lot of ways to make this works... and nothing.
Do you have any solution to this issue? thanks! (if you talk in spanish i'll aprecitatte it)
Allan_J_Intel1
The Intel engineering department is aware of this thread and they are currently working to get this issue resolved. I still do not have an estimate time of resolution but you can keep checking this post for updates.
Allan.
GPetr2
Hello! I have the same issue. Lenovo V570 with Intel HD Graphics 3000 and TV LG 42LA620V and 'no signal' (but cable is detected) situation. I want to know - you said that the Intel engineering department is aware of this thread - is they find some solution? 6 months gone.
P.S. Sorry for my (I think) bad english.
Allan_J_Intel1
Thanks for the information.
I am sorry for the delayed answer. I understand this situation has been escalated previously, however, I still do not have notifications that it has been fixed.
Keep testing drivers that Intel released on 4/10/2014.
Please filter by operating system and try to install the driver when it finishes downloading, to verify that your system will accept it.
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProdId=3319 https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProdId=3319
Allan.
GPetr2
Thanks, Allan. But I have these drivers since it's release, and it didn't solve the problem. It's so frustrating. It seems that Intel forgot about old processor series. I can understand it, but it so pity. My hope about solving this issue is melting, but still present. Allan, thanks a lot. I'll wait for some solution and/or answer patiently.
