23821 Discussions
Intel(R) PCIe Controller (x16) - 1901
FChli
This device cannot start. (Code 10)
anyone know what is this??
also I can’t seem to detect my second gpu (nvidia) once this popped up in device manager.
AlHill
You need to either update your bios, and correctly set the video options, or work with the motherboard manufacturer to get the video set correctly in their bios.
Doc
Lewis-H
There is always the chance that the error Code 10 you're seeing on a device was caused by some temporary problem in Device Manager or with the hardware.
Undo the change if you can, restart your PC, and then check again for the Code 10 error.
Depending on the changes you made, some solutions might include:
  • Removing or re-configuring the newly installed device.
  • Rolling back the driver to a version prior to your update.
  • Using System Restore to undo recent Device Manager related changes.
  • Reinstall the drivers for the device. Uninstalling and then reinstalling the drivers for the device is a likely solution to a Code 10 error.
  • Install the latest Windows service pack. Microsoft often releases service packs and other patches for Windows, one of which might contain a fix for the Code 10 error.
I hope this information helps.
Lewis
shendashu
bios set pci ssid/svid,then install fail
Stefan3D
Did you install the Intel chipset INF driver?
; ** Filename: SkylakeSystem.inf **
; ** Abstract: Assigns the null driver to devices **
; ** for yellow-bang removal and **
; ** brands Intel(R) devices **
If you have a laptop with NVIDIA Optimus, the NVIDIA GPU will not work until the INF driver has been installed successfuly.
Get the INF driver from the OEM's support page
shendashu
It was fail after I updated driver from WEB;It is failed after install intel inf driver also。
Stefan3D
Are you sure that you have the same problem as the topic starter?
Otherwise you should start a new topic.
Describe your issue precisely and attach a SSU report
shendashu
the root case  is that the PEP don’t support D3 status。
Shreeja
Did you use your laptop for any sort of mining or any GPU-intensive task ??
