23722 Discussions
Intel (R) System Usage Report uses a ton of CPU
TheWonderfulPie
Provided SSU
TheWonderfulPie
And it keeps using 25%, it's really, really annoying
LeonWaksman
Uninstall the Intel Computing Improvement Program and you should be free of it. You agreed to install this future during installing Intel DSA but it is not necessary.
Leon
BorisUK2000
Isn't it ironic that an "improvement" program is doing the exact opposite and grinding the system to a halt. I have uninstalled the program which stopped the CPU and fan going crazy. Thanks
Bandit8623
New Contributor III
when its combined with intel arc drivers its hard not to agree to install it....
Limo4317
It is enough to perform a clean restart once as soon as Intel(R) System Usage Report consumes too much CPU...
After the clean restart it only used 0-0.1% CPU for me😁
To do a clean boot, do this: press Windows + R (this opens the command window). There you enter this: shutdown /g /f /t 0
I hope it helps you with this problem😉
