23793 Discussions
Intel R UHD Graphic 630 driver
Pamela
I am looking for an Intel R UHD Graphics 630 driver  for a windows 10.  I am only seeing a UHD not a R UHD can you direct me to the correct driver , Thank you
AlHill
The "R" means registered trademark and does not mean a different driver.
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[Windows 11 is the new Vista]
AlHill
Pamela
Thank you for your response I appreciate it.
