23605 Discussions
Intel UHD 630 Graphics eDP pixel clock limits
myth
I have an Intel i7 9750h UHD 630 laptop with 1440p 165hz display. According to the intel datasheet the uhd 630 video card supports HBR2 via eDP port.
According to the display port 1.2 specifications, 8 bpc 720mhz or 17.28Gbps data transfer can be done with HBR2.
But I can't reach these values on my computer.
When I edit my monitor edid information, the pixel clock limited to 655.35 mhz in the Intel driver detailed resolution section, but if I add a resolution in the DisplayID 1.3 extension block, I can reach up to about 668mhz pixel clock limit.
According to the original edid data of my display, it works at 704mhz, but I can't use it without editing edid because I can't go up to this value.
My question is why there is a limit of 655.35 mhz and how did I exceeded this limit with the displayID extension block? And why can't I go above a 668 mhz? Isn't the limit supposed to be 720mhz?
I have attached some explanatory pictures below.
MUC
Honored Contributor I
So you're trying to put a BOE laptop display into operation. The MSI GL65 9SE-225 device originally has a display with 1920 × 1080 @ 120 Hz, which according to the system circuit diagram above is connected to the Intel Coffee Lake GT2.
Intel UHD Graphics 630 is stated as shown in one of your screenshots with a maximum of 4096 × 2304 @ 60 Hz 8 bpc (= 2560 × 1440 @ 144 Hz) >>> 605 MHz Pixel Clock (CVT-RB v1). This is probably the tested and released limit. Since the required pixel clock is above the Intel specs, it is probably due to limitations in the drivers, neither of which were designed for your new display, even if the maximum is theoretically 720 MHz pixel clock. I don't think there's anything you can do here.
MUC
These are the Video Electronics Standards Association (VESA) parameters for Coordinated Video Timing - Reduced Blanking (CVT-RB):
v1
v2
Aspect Ratio
16:9
16:9
Pixel Clock
699.5
679.1
MHz
H Active
2560
2560
Pixels
H Front Porch
48
8
Pixels
H Sync
32
32
Pixels
H Back Porch
80
40
Pixels
H Sync Polarity
Positive
Positive
H Freq
257.169
257.235
kHz
V Active
1440
1440
Lines
V Front Porch
3
105
Lines
V Sync
5
8
Lines
V Back Porch
111
6
Lines
V Sync Polarity
Negative
Negative
V Freq
164.958
165
Hz
Your laptop display appears to require custom timings, which may only be possible in the driver that the laptop manufacturer has customized. Are you using the laptop manufacturer's driver or the generic Intel driver?
myth
CVT-RB2 is 679.1 mhz pixel clock. But my display not working when i try bigger then 668mhz pixel clock. I am using latest driver from intel right now which is (31.0.101.2125) also tried with OEM drivers but still stuck at 60hz. I want to use my monitor without editing custom timings. I dont understand why my limit is 668 mhz while HBR2 supported ?
MUC
Could you please specify the laptop model?
myth
MSI GL65 9SE Its not my stock display i just changed, it supposed to work but it doesn't.
MUC
myth
Thank you for your explanations. I also didn't know that my DisplayPort is directly connected to the external gpu, which is good for me.
Apart from that, I share below some data I found for who are interested in this subject.
There are many 10th generation core processor devices sold in the market with 1440p 165hz panel. When I look at the specifications of these panels, the pixel clock values are at maximum 667 - 668 mhz. Unlike to the maximum value mentioned in the Intel datasheet, 668 mhz value can be reached. I can confirm this with my own device and a few other devices that I have tested.
Long story short, 668 mhz seems to be the real pixel clock limit for eDP in devices for the 9th and 10th generation. Since there is no software/mod that can exceed this value for now, there is nothing we can do.
