23278 Discussions
Intel UHD 770 - only 1 Monitor with 75Hz possible - Why?
BigCrack
Hey
I use 2 Samsung LS27A600U monitors. But in settings a can just 1 monitor set to 75Hz. The one who is connected to HDMI 1 at PC. The other monitor (connected to HDMI 1) max 60Hz
Sam monitors. Same cables. Same settings.
Intel Arc Control 32.0.101.6078 (13.09.2024)
Any ideas what can be wrong? Thank you!
DeancR_Intel
Hi BigCrack,
Thank you for posting in the Community!
I would like to inform you the following:
  • There is different HDMI versions that may affect the Maximum refresh rate due to bandwidth limitations, so it is recommended to use HDMI 2.1 for the best experience.
  •  If possible, try connecting one or both monitors using DisplayPort instead of HDMI. DisplayPort often supports higher refresh rates more consistently than HDMI
Here's the link for reference:
What Is the Maximum Refresh Rate Supported by the Intel® UHD...
Dean R.
DeancR_Intel
Hi BigCrack,
Dean R.
BigCrack
Hi
Thank you for your effort. But unfortunately this answer is not helpful.
UHD 770 - no 2 DisplayPort - my monitors also not.
HDMI cable is 2.1
One HDMI output of the graphics card can be operated at 75Hz. Only the second HDMI output only works up to 60Hz. That is the question why this is the case.
BigCrack
MUC
Honored Contributor I
Please provide the manufacturer and model of the device you are using. If you built the computer yourself, please provide the manufacturer and model of the motherboard.
Please also create a Report for Intel Graphics Drivers and attach the output file here.
BigCrack
Of course.
Very Gladly.
It's Acer TC-1760
MUC
So you connect here?
According to the manual, the following applies to the Samsung monitors:
  • Resolution: 2560 x 1440
  • Refresh rate: 75 Hz / 60 Hz
  • Pixel clock: 304.3 / 241.5 MHz
This leads me to believe that only one of the two HDMI ports corresponds to version 2.0. The integrated graphics can only work up to 300 MHz pixel clock in the HDMI 1.4 version. Therefore, I suspect that HDMI port #2 is only version 1.4.
Unfortunately, there is nothing that can be done about this. If you want to know exactly, you would have to ask Acer Support, because the inner workings of this PC, including the HDMI ports, were designed by Acer.
DeancR_Intel
Hi BigCrack,
I have noticed that @MUC given out some recommendations for this inquiry. Have you had a chance to review it? If you have any questions or need further information, please let me know.
Dean R.
BigCrack
Hi @DeancR_Intel
Yes and no.
If Intel can't help and it is a problem of the pc and not the graphic... I do not have a solution. 😞
So you can close this.
