23833 Discussions
Intel UHD Graphics Control Panel will not save Wireless Display settings
EvilConCarne
Hello 🙂
When sharing my laptop screen to my TV via wireless connection, the screen doesn't fit. So after some digging around, I found that in the Intel UHD Graphics Control Panel Wireless Display settings, picture size is set to 85%, so I'm guessing that might be the solution to my TV Screen issue.
Problem is I can't seem to be able to change this setting. Even after I set it up to 100%, nothing changes, and after I click "Apply", it doesn't seem to save the new setting and keeps reverting it to 85%.
Any ideas on how this could be fixed?
Thank you 🙂
AndrewG_Intel
Hello EvilConCarne
It is worth mentioning that neither Intel® Graphics Control Panel nor Intel® Graphics Command Center supports Wireless Display. This is implemented by the operating system (Windows®). In this scenario, our recommendation is to contact Microsoft® for support. Here is the Microsoft® Support contact link*: https://support.microsoft.com/
For more information, please also refer to the following links:
Please keep in mind that this thread will no longer be monitored by Intel since we will proceed to close it now from our end; however, communication with community peers can continue. If you need any other information, please submit a new question. Thank you for your understanding.
Andrew G.
*Links to third-party sites and references to third-party trademarks are provided for convenience and illustrative purposes only. Unless explicitly stated, Intel® is not responsible for the contents of such links, and no third-party endorsement of Intel® or any of its products is implied.
