23791 Discussions
Intel arc control application
ozenfurkan
Intel® Arc™ & Iris® Xe Graphics - BETA - Intel arc control application won't open after updating Windows* installation
31.0.101.4576
July 24, 2023
MSİ STEALTH 17M İ7-1280P RTX 3060 Windows Home ınsıder 22631.2115
Andres_Intel
Hello ozenfurkan,
Thank you for posting on the Intel®️ communities. I am sorry to hear that you are having issues with Intel® Arc™ Control Software, I will be happy to help you.
To have a better understanding of the situation, please answer the following questions:
Andres P.
MichelN86
There are more people including my self with this issue. Maybe intel should do some tests before releasing stuff that does not run well.
My older driver Intel® Graphics Driver 31.0.101.4575 for Intel® Arc™ Graphics was running great till i updated to the latest one Intel® Graphics Driver 31.0.101.4577 for Intel® Arc™ Graphics and I even tried the beta one Intel® Graphics Driver 31.0.101.4578 for Intel® Arc™ Graphics.
What i did.
1. Installed the Intel® Graphics Driver 31.0.101.4577 and deleted all older drivers from 4575 within the app.
2. Rebooted the machine
3. Intel Arc does not startup, when i press alt+o i dont see any activity at all from it.
So i removed arc completely from my system using start and navigate to the app and delete it from there and started all over.
Same results
1. Installed the Intel® Graphics Driver 31.0.101.4578 beta
Same results
The only thing that fix arc is to shut down all activity and restart the app. The issue lies with intel.
Andres_Intel
Hello ozenfurkan,
Andres P.
Andres_Intel
Hello ozenfurkan,
@MichelN86 if you need help for your issue I recommend you to make a new post and we will be more than glad to help you.
Andres P.
